Old 01-23-2016, 09:50 PM   #1
wmbuttion's Avatar
Cedar Creek
Unit moves or shakes when anyone walks. Has the 6 point leveling system. Can anyone help. Thanks
wmbuttion is offline   Reply With Quote
Old 01-23-2016, 10:14 PM   #2
lgray's Avatar
Blocks under the jacks to get their extension as short as possible and X-chock the wheels.
lgray is offline   Reply With Quote
Old 01-23-2016, 10:22 PM   #3
wmbuttion's Avatar
Thank you. The unit is a 2015 38RD. We'll do that
Old 01-23-2016, 10:35 PM   #4
lgray's Avatar
No problem. We keep our Trilogy fiver as a seasonal and have added 4 Ultra-Fab Aluminum Stacker Jacks. Keep in mind, while these measures will help, it is very unlikely you will ever remove all the movement.
Old 01-24-2016, 12:05 AM   #5
Mine has always moved. We don't even notice it anymore
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 01-24-2016, 08:35 AM   #6
Certified Curmudgeon
In addition to lgray's sage advice, we put a tripod stand under the king pin and two aluminum trailer screw jacks under the trailer hitch. Tripods are available online and used ones appear to be plentiful. We also used it to chain our bikes to so they didnt pedal away. The screw jacks were easily found at wallymart in a box of 4. We were parked on a concrete pad for 8 months and never felt any movement walking inside. We did feel a little when someone was going in or out.
Mike Dropped
Old 01-24-2016, 08:51 AM   #7
That is where Step Supports come into play! Youroo!!
Old 01-24-2016, 09:02 AM   #8
lgray's Avatar
If I was traveling and had to choose between a tripod and stacker jacks, I would opt for the jacks. They will take up no more room than a tripod and provide better overall stabilization. We have two, right behind the front jacks and two in the rear, either behind the rear jack or on the bumper area…preference. We found that a hydraulic 6 jack system, like yours, there was no added benefit from a tripod and gave it away. The hitch area was not where our movement was being generated and it was just in the way.
Old 01-24-2016, 09:04 AM   #9
heavynlori's Avatar
If you are set up for 8 months, why not build a set of nice wooden steps and not use those rickety metal ones?
heavynlori is offline   Reply With Quote
Old 01-24-2016, 09:19 AM   #10
lgray's Avatar
Exactly, easy job three pre-maid stair stringers, stair treads, support wood and screws, $150.00 from Lowes.
Old 01-24-2016, 09:19 AM   #11
If we were setup for that Long we would (Buy a House)! This is a Travel Unit! Youroo!!
Old 01-24-2016, 09:23 AM   #12
heavynlori's Avatar
We are seasonal for 7 months and would never use those metal steps either....so much nicer for us and our camping chocolate lab to use a nice sturdy set of carpeted steps 😊
cedar creek
