Old 06-23-2018, 02:57 PM   #1
Cedar Creek front baggage area
My 29RE front baggage area does not seem to be strong enough to put anything heavy in it other than spare tire...could it be reinforced to handle two 2000w inverter generators???
Geomonk is offline   Reply With Quote
Old 06-23-2018, 03:27 PM   #2
Hi,
I have no apprehension about putting weight in the front compartment of my Silverback, and in the first year I had it, I carried two Honda 2000s in there.
But I was always a little troubled by the gas fume potential, even though it was largely theoretical. So now my air compressor, spare hoses, BBQ grill, screen enclosure, and other stuff rides there. While it may not be exactly equivalent in weight, those items approach the weight of the Hondas.
And now in my third year of heavy use, I see no distortion of the floor or other signs of stress.
Hope this helps you decide how to proceed.
Rich Phillips
Rich Phillips
2009 K-2500 Duramax
2014 Silverback 33RL
richp is offline   Reply With Quote
Old 06-23-2018, 04:26 PM   #3
The front compartment was originally designed for a generator. If no genny is ordered the compartment has a cheap sheet metal floor dropped in.
donniedu is offline   Reply With Quote
Old 06-23-2018, 04:28 PM   #4
I carried four six volt batteries in there plus a 2500 watt inverter plus some other stuff
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 06-23-2018, 04:48 PM   #5
BuzzWolfAR's Avatar
I had the same concern, but have carried a lot of stuff in there, pancake compressor, coolers with ice, cases of drinks, etc. No issues.
Buzz & Jo Wolf
5er: 2018 Cedar Creek 29ik
TV: 2014 F350 Diesel
BuzzWolfAR is offline   Reply With Quote
Old 06-24-2018, 01:24 PM   #6
iowaborn's Avatar
Send a message via AIM to iowaborn
I cut a sheet of 1/4 plywood to cover the floor. It spans the support members and is substantial enough to hold the weight of stuff I store there.
iowaborn is offline   Reply With Quote
Old 06-24-2018, 03:16 PM   #7
X2
rock-rocker is offline   Reply With Quote
Old 06-24-2018, 08:13 PM   #8
Originally Posted by rock-rocker View Post
X2
X3...1/4" ply --caulked around perimeter then carpeted....Carry big tool box jack and small fridge ++++++ No PROBS in 4 yrs
Jim in Halifax is offline   Reply With Quote
Old 06-25-2018, 07:22 AM   #9
iowaborn's Avatar
Correction - I used 1/2 inch plywood
2013 F-250 CrewCab 6.7 PowerStroke 4X4
2017 Silverback 33RK
Old 06-25-2018, 09:54 PM   #10
I added another angle iron under the area. It was 1/8" plastic on 12" o.c. angles. Plus the existing angles were dribble welded. (those are the ones you don't show your friends when you are learning to weld).
2017 Ford F350 LB SRW 4x4
2016 Cedar Creek Silverback 29RE
BigRockr is offline   Reply With Quote
cedar creek
