Originally Posted by eddy53
We bought a champagne 38el and the water heater flow sensor failed in 1st month and Both! Air conditioners failed the gas leaked out with less than 2hrs work in them, and that means 2 new unit's which as we live in UK I'm not going to get, really think before you buy any forestriver ceder creek 5th wheel.
Sent from my SM-T715 using Forest River Forums mobile app
I am curious on your AC issue, did you change the voltage on your trailer to agree with the voltage used in England? If not this could be why the AC units failed. Even though the unit is 50 AMPS it is still 110/115 volts, 60 Hz. England's electrical system if I remember correctly is 230 volts 50 Hz. This will burn up any US made electrical appliance, if no voltage convert was not used.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
