Old 04-15-2014, 06:14 AM   #1
ret2006's Avatar
Cedar Creek LED front cap light
Anyone know how to remove or replace the LED front cap lights? I read that the LED bulbs in the new Cedar Creek's have a lifetime warranty. I have one that has two LED's out. I don't know how to remove it. I didn't want to dig in to the rubber ring around it for fear of damaging something. Has anyone had these replaced under the warranty? How do you get them out?
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 04-15-2014, 06:22 AM   #2
Chewie's Avatar
If they are like regular trailer lights, the light is just held in with the rubber grommet. Try gently pulling on the light itself and it should pop out. Then remove the rubber seal.
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
Old 04-15-2014, 07:41 AM   #3
Certified Curmudgeon
They are pucks mounted in a rubber ring. If you have a painted cap, the grommet may need a careful trim around the perimeter to prevent peeling.
Now with that said, those LEDs have a lifetime warranty so why not let the dealer do it???
Mike Dropped
Old 04-15-2014, 10:29 AM   #4
ret2006's Avatar
Dealer would do it no problem but they are a 300 mile round trip for me.
Old 04-15-2014, 05:17 PM   #5
You can also contact the East Cost Warranty Administrator. We worked with Danette Ray and she had the interior LED modules right out to us. She has left/been replace by:
Denise Davis (East)
dldavis@forestriverinc.com
Phone (260) 593-2425
Fax (260) 593-3018
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 04-16-2014, 08:44 PM   #6
arpipeliner's Avatar
Pulled one of the front lights. Had to use O rings picks. Was unable to see the front pin box brace due to the wood. Took a couple tries but got it out with some scratches but not easily seen. The trick was reading the top on the lights and pulling them that way. The top marks were sideways in stead of up and down. Hope it helps. My is a 29 RE. The lights were spliced with wire nuts.
arpipeliner is offline   Reply With Quote
cedar creek, led, light
