Old 05-16-2014, 06:17 PM   #1
ret2006's Avatar
Cedar Creek Remote
I have had my 2014 Cedar Creek 34 RLSA for almost a year with no problems until recently. The remote control that operate awning, slides, porch light and leveling legs, has stopped working.
When I press the ON button the little blue light in the upper right corner lights like it is suppose to, when I press any of the buttons, i.e. awning, slides, etc., the button lights but when I press retract, or extend nothing happens and all the lights go out and it seems to shut down.
Anyone had this type of problem? Would the battery need replacing, it hasn't been used much?
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 05-16-2014, 06:25 PM   #2
Oakman's Avatar
I'd replace the battery and go from there. Many times there is just enough battery power to illuminate a light on the device itself but lacks the power to actually transmit.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-16-2014, 06:58 PM   #3
Same problem - new battery
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 05-17-2014, 12:20 AM   #4
Former Full Timer
Duckogram's Avatar
X3
Target has usually has them.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 05-17-2014, 01:32 PM   #5
wanderer69's Avatar
Sync
You may to re sync the remote with the controller. I had to do this one time. Check your manuals there is instructions for doing this and should only take a minute. The controller will be located in the front storage area along with a lot of the other electrical stuff.
wanderer69 is offline   Reply With Quote
Old 05-17-2014, 01:57 PM   #6
Had this issue a couple of times on my 2012 CC and a new battery will fix the problem.
Pitcrew18 is offline   Reply With Quote
Old 05-18-2014, 10:47 AM   #7
ret2006's Avatar
New battery did the trick. These remotes must consume a battery fairly fast. Hadn't used it much in the past 10 months.
But good to know it is as simple at the battery.
Old 05-21-2014, 08:38 AM   #8
mtcreeker's Avatar
In addition to replacing my battery every year. It seems to make a difference how I load my basement and how high items are stacked. I don't know if some of the items may block the signal or what but it has seemed to make a difference.
Steve & Carol
2013 Custom 36 CKTS Cedar Creek
mtcreeker is offline   Reply With Quote
cedar creek
