Old 10-15-2016, 06:40 PM   #41
Left Coast
Distance between the two won't change.....the're still hooked together...
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
Old 10-16-2016, 07:09 AM   #42
Thinking about it, yes it would be the same.
So then back to my other question, does anyone have any idea of the turning degree of a TT? I'm a visual person.
ldmc is offline   Reply With Quote
Old 10-16-2016, 08:04 AM   #43
tkmi's Avatar
I have a 2500 Dodge. Crew cab 6.5 short box with no slider. When I picked up my silverback I had the dealer jacknife it while I watched. I had 1/2" clearance at 92 degrees.I drove truck for 43 yrs. And I don't back up more than 45 deg. If needed use more pullups.
2013 Silverback 33RL
2010 2500 RAM 6.7L
tkmi is offline   Reply With Quote
Old 10-18-2016, 07:59 AM   #44
Does anyone who has a Hathaway and a short bed truck with no slider, have pictures of them backing in at max degree?
Thanks for all the input and opinions. I like this site.
Old 10-18-2016, 12:08 PM   #45
Jim34RL's Avatar
As I have stated earlier, you have two choices either buy a slider hitch and not dent or break a rear window! Or buy a static hitch and hit the cab and break a rear window some time in the future.
I am towing a 34RL Hathaway edition Cedar Creek with a short bed Ram Mega Cab truck. The only time I use the slider hitch is backing into a camp site or my drive way, I don't have to worry about hitting the cab. I have a low cost Reese sliding hitch no need for an expensive slider hitch, I activate the hitch to allow it to slide and I am good to go.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, 100K+miles
Old 10-18-2016, 12:22 PM   #46
I agree with Jim. I went back to read your original post and I assume you already have the Curt 24 5th wheel hitch? I can understand not wanting to buy a new hitch but the first time you bust out your rear window it will have more than paid for itself. Another option is change your Kingpin to a Sidewinder. I'm not sure if they work with a Curt hitch but if they do you can spend ~$700 for a manual slider (Reese 16K) or couple hundred more for a Sidewinder. I have the Reese 16K manual slider and wish I had the Sidewinder. It's not if, it's when..
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 10-18-2016, 12:24 PM   #47
Left Coast
There's a slider for sale right now in For Sale section ....couldn't get a better deal!
Old 10-19-2016, 04:22 PM   #48
Thanks all for you opinions and suggestions.
Looks like a slider or sidewinder is in future before I get the trailer.
Need to budget for it now.
Old 10-22-2016, 09:07 AM   #49
camper1999's Avatar
I have a Silverback and a short bed with a 6.5 foot bed. No slider. The silverback you will never need a slider.
2011 GMC 2500HD Diesel
Old 10-22-2016, 09:22 AM   #50
Have you tested that? I have intentionally backed until I could back no more before I hit. I can't do more than May 75-80 degrees... might want to do a test..
2016 Siverback 33IK
cedar creek
