Old 02-19-2015, 07:34 AM   #1
ret2006's Avatar
Cedar Creek Water Filter removal
As soon as the weather gets better I plan on removing the water filter/housing from my CC 34 RLSA. I have read where many people have had these housing break. Since the only place you can get the filters is from Forest River and they are over priced, it is time for the filter to go.
You that have eliminated the filter, what is the best way? Any pictures? My guess is to just cut the PEX fittings off on either side of the filter and run a cross over PEX line using Shark Bite fittings.
I have noticed looking at pictures of the new CC 5th. wheels there is NO filter unless they installed it somewhere else.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 02-19-2015, 07:43 AM   #2
KyDan's Avatar
We use a "whole house" filter with standard size cartridges. I just added
male and female hose adapters and we put it right on the side of
the RV when connecting to city water supply. You can get them at most
any home supply store or well stocked hardware store or even Wallyworld.
You can also get single use and toss hose filters in the RV isle of most big
box stores but I like the idea of cheaper replaceable cartridges.
Happy Trails!
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 02-19-2015, 12:07 PM   #3
I just removed the filter element but left the empty housing. Unless it freezes (unlikely) or just spontaneously breaks, it's no longer a threat. That was easier than patching with sharkbite, etc.
F-350 Dually
Cedar Creek Silverback
Mazda Miata TOAD for sex appeal
danno2u is offline   Reply With Quote
Old 02-19-2015, 12:27 PM   #4
BamaBob's Avatar
*shrug* we go to the FROG Rally at Goshen every year - they replace our water filter for free. So if you are going this year...just say'n
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 02-19-2015, 12:39 PM   #5
SilverbackMel's Avatar
Filter is a run through device. In winter, pump rv anti freeze through it and system. When finished, unscrew and pour anti freeze into sink traps. In Spring, Summer or Fall simply use a filter of your choice, outside on hose to outside water source or inside. Lot's of choices for the NON HANDY folks 😄.
SilverbackMel is offline   Reply With Quote
Old 02-19-2015, 01:27 PM   #6
I replaced it with a unit from Lowes which use standard filter types. Mounting is still the same
palmetto rogue is offline   Reply With Quote
Old 02-19-2015, 01:53 PM   #7
NCBBA11043's Avatar
I plan on adding one if the 33IK doesn't come with it. I thought this would be an easier way of sanitizing the holding tank. Make a batch of bleach/water, put it in the filter housing (no filter), run some water. Repeat as required. Otherwise, I don't see any easy way of getting bleach/water into the tank via gravity feed.
NCBBA11043 is offline   Reply With Quote
Old 02-19-2015, 03:30 PM   #8
Water filter replacement
Camco makes to filter cartridges that fit perfect the 40621 or 40624 you can get them from Amazon for about $12 each. One thing I was told by dealer when you winterize the filter you can leave the canister off or make sure the threads on the canister are completely dry, no water on the threads that's thats where then tend to crack. I use the compressed air method, no antifreeze except in the P traps and toilet bowl to keep the toilet seal from drying out.
edcronin01 is offline   Reply With Quote
Old 02-19-2015, 06:38 PM   #9
I installed a water heater by pass on the filter to help with winterizing and in case it breaks
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 02-19-2015, 07:09 PM   #10
B and B's Avatar
I bought 3 filters for 25 bucks at Goshen. Pretty good deal! The guy that owns the company sell water softness as well. Bought one for half price, just like home now when I shower.
Old 02-20-2015, 06:43 PM   #11
I just picked up my 36CKTS last week ordered last of November built last week of January. No water filter.
2015 CC 36CKTS
2011 Ford F-250
2003 Harley Ultra Classic
2015 Cedar Creek 36 CKTS
2016 Ford F350 DRW
2016 Harley Davidson Ultra Classic Low
rick03hd is offline   Reply With Quote
Old 02-21-2015, 05:52 PM   #12
Mddle of the Rd Extremist
MeepMeep's Avatar
Completely removed mine as it was a total P.I.T.A. when it came time to change filters.... just built a bypass with PEX line and two 90deg brass fittings in case I wanted to install a different filtration unit later. In the meantime, our in-line hose end filter seems to be doing a pretty good job
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 02-21-2015, 06:14 PM   #13
Picked up our 38rd and had no water filter. The brochure showed that but guess they decided to remove. Sounds like a wise move.
Tom & Marilyn
2013 Chevrolet Duramax 3500 HD LTZ Crew Cab Long Bed Z71 4X4
2015 Cedar Creek 38RD Hathaway Edition
ttanous is offline   Reply With Quote
Old 02-21-2015, 06:58 PM   #14
ret2006's Avatar
What size PEX line is in the Cedar Creek? Did you use Sharkbite 90's?
Old 02-22-2015, 12:04 PM   #15
BamaBob's Avatar
DO tell?! What company was that Brian?
Old 02-23-2015, 08:41 AM   #16
Yep. 2015 38CK delivered yesterday. No water filter.
Gordog is offline   Reply With Quote
Old 02-23-2015, 10:16 AM   #17
Ret E-9 Anchor-clanker
donanddona's Avatar
Your filter is in a better location than mine. I would remove the filter and let her ride. It looks as if your canister fails it will just flood out? My filter is located inside under the steps. I to removed the filter (we use the blue torpedo inline).
donanddona is offline   Reply With Quote
Old 02-23-2015, 01:22 PM   #18
MeepMeep's Avatar
Half inch PEX and shark bite 90's....
MCPO (Retired)
Old 02-23-2015, 04:31 PM   #19
ret2006's Avatar
Thanks Dan. When I De-winterize my Creek the water filter WILL be gone.
Old 02-23-2015, 04:38 PM   #20
You can also pick up good filters @ Lowes, 2/$9 that work great.
cedar creek, water, water filter
