Old 04-17-2011, 10:36 PM   #1
changeing out old tv to high def
we just purchased 2004 cedar creak and would like to upgrade old tv's to high def flatscreen and satellite will we need to upgrade the coaxel cable also has anyone else changed or added satellite? looking for hints and advice
thanks
jon
jalvin is offline   Reply With Quote
Old 04-17-2011, 10:45 PM   #2
ken0042's Avatar
Satellite requires RG6; I would think that a trailer that recent would use RG6. RG59 (which is a lower grade) will work to a certain extent; but I have seen receivers blow their power transformer. The key is receivers send power to the LNB (which is the antenna on your dish), and RG59 isn't high enough grade for any length of run.
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is offline   Reply With Quote
Old 04-18-2011, 06:45 AM   #3
Grape Escape
If you are just using antenna existing cable lines are fine. Trailers usually have 2 connections. One for sat and the other for antenna or park cable tv tie in.
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
