Old 08-25-2015, 07:08 AM   #1
Checking water level in batteries
I have a 2015 36ckts and would like to know how to check water level in batteries without removing them.
GaryO is offline   Reply With Quote
Old 08-25-2015, 07:19 AM   #2
Jim34RL's Avatar
You might be able to buy a mechanics mirror from NAPA and check the batteries that way. These work very good and I have used them when trying to find a hidden bolt on an engine. Otherwise you will need to remove them to check the water level in the batteries.
Or you could replace them with AGM batteries and never check the water level again.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 08-25-2015, 07:35 AM   #3
jeff64's Avatar
I suppose you could use a half a dozen toothpicks ( or similar wood substitute)... like a dipstick and look for the wet level. Probably easier than a mirror and flashlight. If you poke it down far enough to stop, you are touching the plates. If you don't have a wet line about a 1/2 " up from that point, I'd say add distilled water. You want the top of the plates covered. The bottom of the split ring is probably a good 3/4" below the top of the opening. That would be your proper fill level.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 08-25-2015, 11:09 PM   #4
Campingnut's Avatar
I use this system https://flow-rite.com/battery-wateri...rv/pro-fill-rv and I guess I just trust that it works in every cell. So far so good.
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
Old 08-26-2015, 12:33 AM   #5
Just a member
kandl's Avatar
X2 and that would work provided there's enough head room to remove the vent plugs. There are even inspection mirrors with LED lights integrated into the mirror frame:
Amazon.com: inspection mirror with light
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
water, battery
