Old 10-03-2015, 08:01 PM   #1
ret2006's Avatar
City/Gravity water valve
All of a sudden my fresh water tank is slowly being filled when I have the valve in the "city" position. Has any one had this happen and how difficult is it to replace? Where would I get one like is used on the Cedar Creek?
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 10-04-2015, 05:18 AM   #2
fonzie's Avatar
Usually it is the check valve in the water pump that leaks. I would disconnect fresh water supply, start water pump and run a few minutes with faucet open. Reconnect fresh water supply and hope it fixed it.
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 10-04-2015, 05:58 AM   #3
KyDan's Avatar
What he said!
Turn off city water.
Turn on water pump.
Open and shut a faucet several times- cycling the pump.
Sometimes a speck of sediment will find it's way into the check valve
built in the pump.
This often takes care of the problem.
Good Luck!
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-38
KyDan is online now   Reply With Quote
Old 10-05-2015, 08:28 PM   #4
Mine did something very similar and it turned out to be a faulty Anderson Water Valve. Dealer replaced it under warranty and problem solved
Jim.mcgallan is offline   Reply With Quote
