Old 08-30-2013, 10:37 AM   #1
clogged shower drain?
I recently moved into my cedar creek 5th wheel for full-time living. It is parked at a park so it does not move often.
Currently I am experiencing an issue with a clogged shower drain. I am sure that this is due to the fact that I have long hair and it sheds.
I was wondering if I can use a standard home drain cleaner (i.e. Draino) or if it is too harsh for the RV and I need to do something else.
chiefswife is offline   Reply With Quote
Old 08-30-2013, 10:47 AM   #2
Always Learning
I have no idea what is/isn't safe.
But my family is a bunch of wookies (myself included- I have a long flowing mane that many women have killed for trying to simply touch).
We use a stainless strainer in our shower in the camper. I took the shower stopper out and set this in its place. We have to clean it out after every shower, but it keeps the hair out of the drain and out of the tank.
Hopefully someone comes along and posts what to do to get it unclogged.
Old 08-30-2013, 10:58 AM   #3
Thanks for the strainer idea, I will certainly use it. Now just to get the thing uncloggged, it has certainly shortened my showers in the meantime.
Old 08-30-2013, 11:12 AM   #4
Arefbee's Avatar
Not sure how Drano will affect the sensor probes so that would be a last choice for me. Plumbers plunger has always worked for our clogs - just use it vigorously and remember that it works best with a couple of inches of water in the basin (tub) and the drawing action really loosens the clog, not the plunging action. A snake would be the next choice.
I have used a shop vac to unclog a drain. It was not pretty, but it worked.
After that the screen is an excellent choice to keep the issue from returning.
2011 PrimeTime Tracer 2600rls
Arefbee is offline   Reply With Quote
Old 08-30-2013, 11:22 AM   #5
Dave_Monica's Avatar
As you have a 5th wheel, you should be able to see and remove the shower drain trap and clean. It should be accessible near the ceiling in the storage basement.
Dave
Old 08-30-2013, 12:07 PM   #6
Certified Curmudgeon
Dave
X2
Also the strainer will work but you can't step on it as it will fold. They are available at Wally Mart for under $3. We use them in the sinks as well. They come in many sizes and are stainless steel.
Mike Dropped
Old 08-30-2013, 12:23 PM   #7
Always Learning
Originally Posted by Duckogram View Post
X2
I use mine upside down (with the nipple pointing into the drain). No worries about stepping on it.
Now, if I could keep my son from thinking it's a playtoy, that'd be great...
Old 08-30-2013, 01:16 PM   #8
KyDan's Avatar
Try fishing the hair ball out of the trap with a wire.
Just a bent piece of wire or a hook made from a wire coat hanger.
You might get lucky and just pull the clog right out.
I've done this many times on our 2nd floor shower drain in our home.
Only access to that trap is by cutting a hole in our kitchen ceiling
Good Luck!
Peace!
Dan & Rita D
Old 08-30-2013, 01:30 PM   #9
You can take a water hose place it the drain with a rag around it. Turn the water hose on and let the pressure unclog the drain. Chemical free solution that will unclog most drains.
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 08-30-2013, 01:35 PM   #10
Always Learning
Good point, Dan. We have these at home for our bathroom sink drains (remember, wookies):
As Seen on TV - Turbo Drain Snake
They really do work.
Old 08-30-2013, 02:11 PM   #11
They also have plastic zip strips at Home Depot that you can run down the drain. I have not used them but they may work for what you need.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
Old 08-30-2013, 02:28 PM   #12
Kaadk's Avatar
Haven't had any clogs in the TT, but I use something like this for the ones at home:
Flexible Grabber Tool | Toolmonger
Couple of bucks at most hardware stores. (I got mine at Canadian Tire.)
Old 08-30-2013, 09:40 PM   #13
Just remember most of the newer CC have a Waterless Valve instead of a P trap...
Hepvo Waterless Valve
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
drain, show, shower
