Old 02-27-2019, 09:40 AM   #1
Compressor? Cordless or Not.....
So, multiple part question!
For those with air ride king pings what air compressor do you all carry with you while traveling?
For those with air bags on your truck what air compressor do you all carry with you or do you have in dash compressor control?
For those that worry about keeping tires at right pressure during long hauls what compressor do you carry?
I am looking for a compressor that works for all three situations!
4garylee is offline   Reply With Quote
Old 02-27-2019, 10:04 AM   #2
Jim34RL's Avatar
I have the TrailAir king pin box I also have air bags on my truck.
First off, I carry two different devices for my trailer. One is a portable air tank that holds 125 psi of air and 5 gallons of air.This I use to inflate the air bag in the kingpin when needed. This way I do not need electrical power to inflate the air bag.
I also have a 165 psi electrical pancake Dewalt air compressor to inflate my trailer tires and portable air tank when I have electrical power at the campground.
For my truck air bags I have an onboard air compressor that adjust the bags air pressure as needed to the required pressure that I set the bags to.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 02-27-2019, 12:20 PM   #3
Fulltime family RVer
Viair. Size it based on your use (read: unless you need high pressure, you don’t need to spend as much!).
Product Review: Viair 450P 12v air compressor | Learn To RV
Old 02-27-2019, 12:22 PM   #4
Fifth Wheelers's Avatar
I use the VIAIR 400P for my king pin and for inflating car and fifth wheel tires while on the road. Do not have air bags can't comment. Like the compressor size along with it's ability to handle airing 110 tires with no problem.
2016 Champagne EL38
2016 Dodge Ram 3500 DWD
Fifth Wheelers is offline   Reply With Quote
Old 02-27-2019, 01:16 PM   #5
Head Rambler
If you have a favorite brand of cordless power tools you're already invested in, look and see if they make a compressor that runs off the batteries you already have and go with that one. Since you probably already have several batteries for the tools (I know I have a bunch) you wouldn't have any added expense battery wise and you probably also have an extra charger or two for them.
Gotta go campin!
Old 02-27-2019, 01:35 PM   #6
LarryBoy's Avatar
I carry a Vlair 88p in my truck at all times for tires and air bag
LarryBoy is offline   Reply With Quote
Old 02-27-2019, 01:49 PM   #7
RV There Yet?
IsleDog's Avatar
I carry a Ryobi battery powered compressor. it does both high pressure, low volume for tires, and low pressure, high volume for beds, beach toys, etc.
its not expensive and not the fastest, but it works and thats all i really care about.
I like that it uses the Ryobi battery pack, same as my portable radio for the fire, drill for stabilizer jacks and small projects, spot light, fan, and soon a thunder gun for lug nuts.
https://www.homedepot.com/p/RYOBI-18...-203060297-_-N
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
IsleDog is offline   Reply With Quote
Old 02-27-2019, 03:56 PM   #8
I have a Viair. Note that it connects directly to the battery (TV or RV) with alligator clips...not through a cigarette lighter.
This is minimally adequate to do the jobs you'd ask of it. I use my jumper cables as an extension cord. Clamp one of the clamps (say red) to the jacket on the other cable (e.g. black) to keep the free end from shorting. Then attach to the battery. Next attach the compressor. Works like a charm.
This model has a pressure gauge which is reasonably accurate. This will inflate a tire to 70 or so PSI quite easily.
So for a single solution, this or a better Viair model will do just fine.
Of course, at home I have a real compressor and use it to setup the rig for travel. The Viair is just for tweaking along the way. The beauty of this compressor is that it will winterize my camper with air in just a few minutes. I set the output pressure to 40 PSI (so as to not blow things up) and this has the reserve capacity to do the whole job effortlessly. This thing never leaves the garage. I just run a couple hundred feet of air hose to the place where the camper is parked.
Jim & Renee
2014 Forest River/Rockwood HW 277
Typical season is about 30 nights camping, usually nearby boondocking in the National Forests or at Lake Wellington
jimmoore13 is offline   Reply With Quote
Old 02-27-2019, 03:59 PM   #9
DouglasReid's Avatar
I carry a 12 Volt Sure Flow air compressor for my air bags and tires on my camper and truck. It is American Made and significantly less expensive than the Viair(which is a VERY good pump too).
Clips to battery in basement of 5er or to truck.
I found it here for less than $150
https://www.tooldiscounter.com/ItemD...gaAi3UEALw_wcB
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 02-27-2019, 04:26 PM   #10
Multi-Slacker
Viair. Size it based on your use (read: unless you need high pressure, you donít need to spend as much!).
+ 1
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
Prodigy P3 Brake Controller
Andersen WDH / 2700 lb 2.5" Receiver
CurtPutnam is offline   Reply With Quote
Old 02-27-2019, 04:31 PM   #11
SailorSam20500's Avatar
Originally Posted by CurtPutnam View Post
+ 1
+2
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 02-27-2019, 04:50 PM   #12
Mr Towed's Avatar
My only need for air is for tires for the truck trailer, and bikes and such. From my Jeep days I have a 12V compressor that I had mounted under the hood that I am contemplating mounting under the hood of the tow vehicle and plumbing to the bumper, maybe with a small tank. I also have one of those little As seen On TV type battery operated ones, which I haven't actually used but it was a gift so I take it along.
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Cats: Rhody and Hazy
Pooch:Sophie the Sato
Mr Towed is offline   Reply With Quote
Old 02-27-2019, 05:15 PM   #13
Hoglou's Avatar
X2 vair
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 02-27-2019, 05:55 PM   #14
I have the Vlair 450P, I love it.
wildcatter is offline   Reply With Quote
Old 02-27-2019, 05:59 PM   #15
Mr. Dan's Avatar
I use a VIAIR 300P. It does all I want/need.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 02-27-2019, 09:22 PM   #16
My wife gave me a pancake 125psi air compressor a few years ago for Christmas and I have two Hondaís but I have never needed air in all the years I have been camping. I have a TrailAir pin box and I normally check it before I start out in the morning, it will normally hold air for a week or more. The tires will normally hold air for the whole camping season
spock123 is offline   Reply With Quote
Old 02-28-2019, 04:12 AM   #17
Was
I have Air Lift bags on my truck with a dash control onboard compressor. I added a coupling to the line , so I can just plug an air hose into the system to air something up. I also carry a cheap harbor freight 12 volt compressor.
Was is offline   Reply With Quote
Old 02-28-2019, 10:48 AM   #18
Send a message via AIM to splong16
X3 on Viair 450. Since it is 12 volt I power it from my 5th wheel batteries. I use it for the tires, pin box, airing up water toys etc. works great.
2017 Cedar Creek 36 CKTS Hathaway
2015 GMC Sierra 3500 4x4 SRW CC
splong16 is offline   Reply With Quote
Old 02-28-2019, 10:53 AM   #19
Jim34RL's Avatar
Will if his Cedar Creek tires are like my tires on my Cedar Creek, the tire pressure is 110 PSI max. This is why I purchased a 165 PSI, 6 gallon pancake air compressor to carry in the trailer. The little 12V air compressors just do not have the capacity to inflate the tires quickly.
Jim W.
Old 02-28-2019, 11:31 AM   #20
I have three axles on my CC as I have the 2019 Silverback TH. I do have the TrailAir Kingpin which your normal gas station pumps don't have enough pressure to fill when needed (noticed they are set to max air around 70lbs) and need 100lbs for the King Pin.
I have the airbags on my dully and looking to install on board compressor and haven't researched if those have enough power utilize by installing a separate line for filling TrailAir Kingpin.
Thank you everyone for your replies they all help a great deal!!!
