Have a 36CKTS. Am jealous of your axle/tire replacement, as it's a total piece of mind issue. However, I am now pretty comfortable with the OEM setup. I got the Joy Rider II system installed and that aligned my axles...which were out 3/4 of an inch from one side to the other. Another guy I know had his out 1 1/2". Those are bad alignments! That alone made the ride much smoother and should help the tires roll better and pull better. It is sort of a 'poor man's MorRyde IS system', at least in my mind.
That said, I am not for these Chinese tires either. BUT, there really hasn't been any (that I know of) reported problems with these specific Westlake 16" G rated tires. I certainly would NOT replace them with same, once they need replaced. But I can't justify the expense of doing what you're contemplating. Nonetheless, I wish I could, and I'm glad that you can, and if I could I'd do it.
FROG AR-0019-242
