Originally Posted by Apache Dave
My batteries died even though connected to shore power at home. I disconnected the positive battery cable on 1st battery (i have 2 wired in series for 24V) and tried lights--nothing. Next step is to connect battery charger to batteries while shorepower tied to house and see if i get lights. I have the converter ordered to change out but want to upgrade complete distribution panel w/converter to Progressive Dynamics but need to know which system is interchangeable without having to modify wall area for installation. My unit is WF 8930/50 with 50 amp service breaker. My converter is WFCO 55 amp--model # 9855. Any information given is well appreciated. I am at work and wife is trying to help me remedy this issue this week so we can leave for Virginia on the 5th of December for a 2 week vacation. Am really trying to make this repair so all systems will function properly while in the mountains. Thx, David
David you need to stay on one thread at a time, you're only getting partial response from everyone cause the threads come to a self close. Now you have 4 threads started on the same subject. As I understand it now, you've concluded the battery charger portion of your converter has died. You want measurements for P/D panels to replace your own. I think Turbo is very knowledgeable on the subject of Progressive Dynamics, also there web site is very complete with lots of choices. All you need to reserarch is AC system 50 amp input. You output should be 55 amps DC or better with matching dimensions. I don't think will be hard to match. Hope ya make it in time, you should be able to.
