Old 12-30-2015, 08:22 PM   #1
CAT-RN's Avatar
Converter question in 38CK
I have a friend with new Cedar Creek 38CK He is having trouble keeping residential refrigerator cold while driving.
I ll post a picture of the converter. It has a red button on it. It Has two positions. One says power on the other remote.
So my question should the button be in or out on the converter when driving ??
RussellClick image for larger version
Name:	ImageUploadedByForest River Forums1451528542.368167.jpg
CAT-RN is offline   Reply With Quote
Old 12-30-2015, 08:25 PM   #2
CAT-RN's Avatar
Pic 2Click image for larger version
Name:	ImageUploadedByForest River Forums1451528736.960364.jpg
Old 12-30-2015, 08:30 PM   #3
does he have the "remote" switch installed somewhere else in the unit?
That is what the button would be for. It allows manual on/off at the unit, and if installed, in "remote" position the remote mounted switch has control.
'14 XLR 395AMP
'16 Ram 3500 DRW, 6.7 cummins w/aisin trans and 4.10 gears
ykdave is offline   Reply With Quote
Old 12-30-2015, 08:32 PM   #4
CAT-RN's Avatar
I thought the remote might be for allowing his truck to run the converter? The front of that converter says something about a remote - He hasn't installed anything. It came like that
Russell
Old 12-30-2015, 08:41 PM   #5
ttanous's Avatar
I run down the road with power on. If you push the button to the other position then it is off. The only time you are providing power to the fridge is when it shows voltage on the display.
ttanous is offline   Reply With Quote
Old 12-30-2015, 08:43 PM   #6
CAT-RN's Avatar
Ok. So if it is showing 13.2. You feel it is powering frig Or should be. Right now it is showing 122 and he is on shore power
Russell
Old 12-30-2015, 09:10 PM   #7
ttanous's Avatar
When on shore power I power mine off. So if he unplugs from shore power then when putting it on then it will show 118-122.
Tom & Marilyn
2013 Chevrolet Duramax 3500 HD LTZ Crew Cab Long Bed Z71 4X4
2015 Cedar Creek 38RD Hathaway Edition
Old 12-30-2015, 09:15 PM   #8
CAT-RN's Avatar
So when you are going down the road and your converter is on. What does it read 13+??
Russell
Old 12-30-2015, 09:48 PM   #9
ttanous's Avatar
Mine reads volts so it usually is around 122 volts and slightly drops to 118 over the next few hours.
Tom & Marilyn
Old 12-30-2015, 09:51 PM   #10
ttanous's Avatar
Just realized you stated converter and not inverter. Yes I am about 13.2 after unplugging from shore power and ready to go down the road. I have 4 - 6 volt batteries feeding the coach.
Tom & Marilyn
converter
