Old 06-17-2016, 09:29 PM   #11
edt
Originally Posted by stretch View Post
etcmss, I see you get up about the same time I do. We just bought a used 2014 cottage 40CCK. On the walk through today the sales rep could not find the switch for the 4 small round lights over the sofa area. The two light switches behind the recliners control the middle 4 lights and the lights over the table. Where is your light switch for the 4 lights over the sofa?
Should be in the door with the slide awning switches
North Ga
2015 40' cls
Never to be moved
edt is offline   Reply With Quote
Old 06-18-2016, 05:40 AM   #12
etcmss's Avatar
my ceiling lights are all switched in the control box in the kitchen. I do have 2 small lamps on each side of the sofa, but there are no switches-just local.
I have 2 switches by the recliners, one for above recliners and one for the dining table, these are for the ceiling lights in the slide.
Enjoy your new (to you) unit. We do like ours.
Gary
etcmss is offline   Reply With Quote
Old 06-19-2016, 08:40 AM   #13
Gary
Correction -- the 2 switches behind the recliners control the lights in the slide - not any of the main ceiling lights. I will start looking for bad bulbs or bad wiring connection. Thanks
2014 Cottage 40 CCK
2015 Ram 2500 Crew 4x4 6.4 Hemi
stretch is offline   Reply With Quote
Old 06-19-2016, 08:47 AM   #14
CANADA FROG RALLY 2017
B and B's Avatar
Our Neighbour has one at our seasonal site. They have had no one out to fix anything in 3 years. One spring the slides did not deploy, needed some hydraulic fluid. No leaks just low from day now.
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
B and B is online now   Reply With Quote
Old 06-19-2016, 10:29 AM   #15
Thanks B and B! That is encouraging!
Rvretired is offline   Reply With Quote
Old 06-25-2016, 10:25 PM   #16
We have our new cottage and we love it; however we cant get the ice maker to work. We have lifted and lower the bar in the freezer and we have found what we think is the bypass valve and turned it the other way. Anyone have a suggestion?
Old 06-25-2016, 11:16 PM   #17
edt
Look for the gally low point drain you will find a blue pipe with a white valve this works backward push to open valve very hard to push. There should be a 1/4 line that pulled out of valve
North Ga
2015 40' cls
Never to be moved
Old 06-26-2016, 05:44 PM   #18
Is it really necessary to turn off the water to the washer when not in use? It takes two people to get to the place to turn off the taps.
Old 07-17-2016, 08:29 AM   #19
We are now in our second season with our 2015 CCK at our seasonal camp in southern Michigan and love it! Our dealer replaced the leaking dishwasher during season one, otherwise it has been trouble free. For us, it has been an excellent choice. It is "glamping" for sure. There are now two others in camp. We installed x-chocks this year which really improved the stability.
cck camper is offline   Reply With Quote
Old 07-17-2016, 09:43 AM   #20
edt
Our cottage will never be moved so I placed it on cender blocks vow very stable
North Ga
2015 40' cls
Never to be moved
