Old 04-18-2014, 11:03 AM   #1
Rich and Char
rich and char's Avatar
cotter pin size
Hi all , does anyone know the cotter pin size for a dexter 7000lb axle w/ never adjust brakes that on our CC 36ckts,
Rich
2011 F350/CC/LB/Diesel/Dually/Bilsteins
2013 Cedar Creek 36CKTS/Trail-Air/Pullrite 20.5K Super 5th/TST-507RV
rich and char is offline   Reply With Quote
Old 04-18-2014, 11:04 AM   #2
Rich
A SWAG would be 3/32" or 1/8" x 2"
Old 04-18-2014, 11:10 AM   #3
B47
Rich
Just take one key out and take it an auto parts store,etc for replacement.
In aviation,we always were taught to use safety wire size so it filled 2/3 of the drilled hole - same thing with cotter keys if you can't get exact replacement size although I'm pretty sure the axle cotter pin is a standard size.
Old 04-18-2014, 11:19 AM   #4
We used safety wire at Lockheed on the MLRS, HIMARS & the PAC3 missiles and the holes were, generally speaking, 3/32" dia and the safety wire was stainless steel 0.032-inch, 0.041-inch, although once in a while 0.020-inch on really small parts.
Sorry for hijacking the thread.
Old 04-18-2014, 11:26 AM   #5
B47
Same with us although .041 wasn't too common and we used .064 in some heavy duty areas.
Used the thin stuff for safetying cannon plugs until the DC-10 came out - most of the cannon plugs on that bird are self locking.
Old 04-18-2014, 11:45 AM   #6
Rich and Char
thanks guys , the next time I work on a plane I'll Know ... lol
Dexter just got back to me with the info , 1/8 x 1.75
I would rather have everything home ready instead of running around the day of.
Rich
Old 04-18-2014, 11:49 AM   #7
B47
Rich
No problem - BTW I should of said in my first reply not to pull your RV with a cotter key removed.
Old 04-18-2014, 11:50 AM   #8
Altho' I have always used cotter pins, on the 'lube thru' the end axles' it would be easier to use two or three strands of safety wire due to the offset hole. I just never went back in the garage and got the wire and pliers to do it. Another case of laziness.
Old 04-18-2014, 12:05 PM   #9
Rich and Char
Why , its less than 5 miles round trip to the parts store ,would that be a problem...he,he,he
Old 04-18-2014, 09:31 PM   #10
Originally Posted by Duckogram View Post
Or, you could treat it like a Chevy and use a nail.
Or treat it like a Ford or Dodge and use baling wire or a coat hanger.
