Old 04-23-2015, 05:06 PM   #1
HeyJude's Avatar
De winterizing for the first time and need help.
We are doing this tomorrow. We are pretty good at doing our other tt, but the silverback looks different. Are all the valves and such pretty much the same? Is there anything specific I should do or look for? Any help would be much appreciated!
Thank you in advance,
JudeAnn
HeyJude is offline   Reply With Quote
Old 04-23-2015, 05:12 PM   #2
The valves will be the same probably color coded blue for cold water red for hot. If the valve handle sets cross ways of the line it is closed. Same as the line runs it is open.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 04-23-2015, 05:13 PM   #3
rattleNsmoke's Avatar
On my Cedar Creek fiver, all the valves have to be pointed IN THE SAME direction to fill the hot water tank and get hot at the faucets. That pearl of wisdom cost me twenty bucks by a mobile RV guy. Embarrassing, yes. Lesson learned, most definitely.
rattleNsmoke is offline   Reply With Quote
Old 04-24-2015, 10:24 AM   #4
dieselguy's Avatar
rattleNsmoke ... behind your hot water heater, the valve in the short line connecting the hot and cold side of the water heater should be closed under normal operation. Other wise, you'll back feed hot water into the cold water lines. It should only be open for winterization to isolate the hot water tank.
dieselguy is offline   Reply With Quote
Old 04-24-2015, 03:25 PM   #5
Former Full Timer
Duckogram's Avatar
JudeAnn
The basics are the same. The only thing that may need "special" attention is your plumbed in water filter if you have one. And this from experience: Don't forget to sanitize ALL of your hoses and pressure regulators.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 04-24-2015, 03:31 PM   #6
Oakman's Avatar
JudeAnn
Here's a diagram of how the three valves on the back of the water heater in your Silverback should be set for normal use and when winterizing.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is online now   Reply With Quote
Old 04-24-2015, 08:01 PM   #7
All vertical for winter all horizontal for summer very easy!!!!
jared.stoltzfusrvs is offline   Reply With Quote
Old 04-24-2015, 09:29 PM   #8
HeyJude's Avatar
Attachment 75117
Thank you. The water is on, but I'll have him look at this.
first time, winter, winterize
