Old 07-19-2016, 08:48 AM   #1
Dehumidifier help
We are experiencing some "wet" ceilings in our camper. Its hot hot hot and humid in good ole South Carolina right now. I run the fan during shower etc. But in the morning, the ceiling and air conditioner vent in the bathroom is very wet. We need to purchase a dehumidifier. We have the Cedar Creek 33ik and I guess my question is how large of a dehumidifier do we need?
Thanks in advance
2016 Silverback 33IK
2013 nights camped 35
2014 nights camped 43
2015 nights camped 91
2016 nights camped 84
2017 nights camped 07 January
freedomfam is offline   Reply With Quote
Old 07-19-2016, 09:43 AM   #2
Head Rambler
Given the size and condition of your RV, I'd suggest something in the 30 pint per day range. You don't want to get one too small. I'd also suggest getting one that you can choose the humidity setting on. One with a large capacity reservoir will increase the times between emptying, but in an RV it may not be a big deal to empty it regularly.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 07-19-2016, 09:48 AM   #3
Flybob's Avatar
I recommend you get one that has the option for a permanent drain connection. I run my 30pt dehumidifier when the RV stored as well. You can get fancy and run the drain through the bottom of the unit (I did) or just run it down the shower drain.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-19-2016, 09:50 AM   #4
As in how high the humidity is? Suggestions where to purchase?
Old 07-19-2016, 09:51 AM   #5
jeff
jeff64's Avatar
I have one of the Evo-Dry electronic dehumidifiers that I bought because of size, noise, weight, cost and power consumption. These peltier types don't cut it for this application. Not enough humidity reduction/run time IMHO.
You'll need the real deal, I think Flybob has the right idea set it in the shower and let it drain out
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 07-19-2016, 09:51 AM   #6
Thanks for that info
