Most residential dehumidifiers are manufactured by only a few companies ( although they may be rebranded under many names). I suggest a good 30 pint residential model. You should try to get one that has the ability to connect a drain hose so you don't have to continually empty it. I do not recommend the solid state ones as they work OK, but do not have the ability to remove much water ( a few oz vs pints). I ran the drain hose through the base of my shower and out the underside of the unit. You can run into a low drain such as a shower drain, but the removed water can contain rust.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
