Old 05-05-2016, 04:32 PM   #11
wls
Originally Posted by adayers View Post
So there is not a lot of information on the hot water tank and how to use it. Did you ever figure out the bypasses and then is it electric and gas or just gas? I thought mine was on but had luke warm water coming out.
I had to take the back panel off mine, I set it to 130, works great
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
2016 Camping Days=38
2017 Camping Days=24
wls is offline   Reply With Quote
Old 05-05-2016, 04:47 PM   #12
adayers's Avatar
Just used my new 36ckts
Where is back panel
adayers is offline   Reply With Quote
Old 05-05-2016, 07:55 PM   #13
wls
Where is back panel
on mine, you slide the door that in the basement. Its by the steps, and vac. then take out 2 screws and locate the tiny-very tiny switches and set them to 130, they are factory set to 120. you sort of have to crawl up in the basement to get to it.
heater, water, water heater
