Old 09-07-2014, 11:17 AM   #1
DIY: 38FL Remote water switch
Ok I wanted to add a remote switch to control the water pump from outside/drivers side of the rig for bathroom stops and when dumping. Kind of crazy not to already have one there of course.
Tools:
Screwdriver
5/16" Socket (battery cable)
3/8 wrench/nut driver (Power terminal)
Drill with drill bits (sized for switch)
Supplies:
SPDT/Three position Switch
14 Gauge hook up wire
Terminal connectors
Shrink tubing
Shut down the power and disconnect ground wire:
Name:	ImageUploadedByForest River Forums1410106674.568820.jpg
Supplies needed:
Name:	ImageUploadedByForest River Forums1410106569.166760.jpg
Pump location behind the docking station and removalable panel - Not the blue wire with fuse holder connects to red wire on pump. This is where the cut is made to insert the switch.
Name:	ImageUploadedByForest River Forums1410106595.607841.jpg
Whole is drilled in the docking station - I put 2 pieces (one on each side) of sticky duct tape to catch all metal bits.
Name:	ImageUploadedByForest River Forums1410106617.893601.jpg
Switch connections with shrink wrap - I split the ends around the screws - probably not really needed but for extra protection. Center terminal routes through the fuse holder and to the pump. One side connects to a 12 volt source and the other connects to the power coming from the inside switch. I took power from the power block for the hydraulics.
Name:	ImageUploadedByForest River Forums1410106630.359345.jpg
Name:	ImageUploadedByForest River Forums1410106657.852016.jpg
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 09-07-2014, 11:26 AM   #2
I grabbed the power from the hydraulics block - terminal next to the red wire heading down to the hydraulics. I didn't worry as it is only for when I use the pump outside switch and I would not be using hydraulics at the same time.
Name:	ImageUploadedByForest River Forums1410107171.934448.jpg
Temp label for the switch - I have some labels being made but just in case I forget until then....
Name:	ImageUploadedByForest River Forums1410107157.505281.jpg
Walter & Donna
Old 09-07-2014, 11:32 AM   #3
Crude wiring diagram:
Walter & Donna
Old 09-09-2014, 08:51 PM   #4
CCRVOC
Ramblin Recks's Avatar
Good idea Walter. Your switch location is where I put a 3-way switch to control the leds strip lighting for the basement. Looks like I'll have two switches there now. Thanks for sharing!
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 1000w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
Old 09-10-2014, 09:36 AM   #5
Added the label to finish it off. Click image for larger version
Name:	ImageUploadedByForest River Forums1410359751.954880.jpg
Walter & Donna
water
