Old 05-06-2012, 11:28 AM   #1
Docking Station Port Hole
Getting the Silverback 35QB4 ready for its first trip next weekend (well, first camping trip - I have a new respect for long haul truck drivers after hauling a## for 3200 miles (5200 kilometres) last week from Iowa back to Alberta in 72 hours...but I digress!
My question is this - what innovations/solutions have you guys and gals come up with to prevent rodents/other undesirables from entering into the docking station when parked at a campsite i.e.. what have you designed to block the port hole through which your water and cable lines come into the docking station?
If you could kindly share your ideas/designs, it would be greatly appreciated so that I do not have to redesign the wheel!
Thanks all in advance!
2012 Cedar Creek Silverback 35QB4 "Silver Edition"
2011 Chev Silverado 3500HD Dually Duramax Turbo Diesel - Allison Trans / PullRite 20.5K Super 5th Wheel Hitch & SuperRails / Trailair Tri-Glide Air Ride Pin Box #21,000 / Honda 3000i Handi
mdamm is offline   Reply With Quote
Old 05-06-2012, 01:07 PM   #2
davidjb's Avatar
mint x garbage bag stuffed into the hole
davidjb is offline   Reply With Quote
Old 05-06-2012, 02:33 PM   #3
Oakman's Avatar
Steel Wool wedged around the water hose. I've only had our Silverback for a month so I can't guarantee this works.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-06-2012, 06:52 PM   #4
Thumbs up Docking Station Port Hole
I like the steel wool idea, but where the heck
do you find a piece large enough?
Old 05-06-2012, 07:23 PM   #5
Crusader's Avatar
I use a plastic lid, with a hole in the center and a slit. That way you can slide it around your water line, and push it into the port hole diameter. ( lid from chocolate milk mix )
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 05-06-2012, 07:28 PM   #6
Crusader's Avatar
If you can find a big enough wachy noodle in diameter, that would also work..........
Old 05-06-2012, 07:35 PM   #7
Thumbs up Great ideas
I like both of those! Thanks.
Old 05-06-2012, 08:33 PM   #8
Oakman's Avatar
You can get steel wool at most hardware stores, but I like the idea of the swim noodle also. I already have swim noodles on the corners of the bedroom slideout to prevent major head knocking.
Bob and Joyce
ATU Local 788
Old 05-07-2012, 11:10 AM   #9
PapaSmurf's Avatar
Have to remember to go out to the pool house this afternoon and cut me a couple of inches off a noodle. I know we have one of the larger ones, because grandma and grandpa are not skinny people.
2011 Ram Truck 2500, Crew Cab, 6.7L CTD, 4X4, 3.73 Rear
PapaSmurf is offline   Reply With Quote
Old 05-07-2012, 12:24 PM   #10
Instead of steel wool, which can rust, I use a couple pieces of copper wool. Found it in the kitchen aisle at grocery store by the sponges.
Old 07-25-2012, 10:01 PM   #11
Old Member
mikey's Avatar
Send a message via Skype™ to mikey
We went to West Marine, bought an extra port hole cover, drilled a 1" hole in one side, cut the threads out next to it and put the hose & cable through our little hole and screwed the cover in place. walla! not rodents!
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
mikey is offline   Reply With Quote
