Old 06-12-2016, 02:39 AM   #1
Does zone 2 AC work independently of zone 1?
We are trying to run zone 2 AC by itself at night to hopefully keep the bedroom cooler. All that is happening is that the ac unit hums very loudly for a few minutes then turns off. After awhile the humming starts again. We turned off zone 2 and turned on zone 1. Just not sure how the 2nd ac is designed to work.
Danny & Esther
2016 38RD Hathaway Edition
2016 F350 Dully
MURRAY5476 is offline   Reply With Quote
Old 06-12-2016, 04:16 AM   #2
CAT-RN's Avatar
Not sure which RV you have ? On my Coach either unit will work independent of the other.
We do what you are trying all the time. Which ever end of the coach we are in we run the opposite AC. To keep the noise away from where we are. Then when needed we run both.
Russell
CAT-RN is offline   Reply With Quote
Old 06-12-2016, 08:14 AM   #3
ttanous's Avatar
We turn zone 1 up higher than zone 2 so that we have cooler in the bedroom. Yes the AC cycles like you mentioned in zone 2. It has to do with the sensor location in the bedroom versus the sensor for zone 1. We turn zone 2 down a lot because we want the coolness in the bedroom. Usually set zone 1 to 72 and zone 2 to about 68 at night. We are in the south. Like it cool.
Tom
2016 Ford Power Stroke F350 Lariat Crew Cab Long Bed Dual Wheel
2015 Cedar Creek 38RD Hathaway Edition
ttanous is offline   Reply With Quote
Old 06-12-2016, 09:06 AM   #4
BandJCarm's Avatar
If I understand it (and I have zero experience until this Tuesday night!!! LOL), the thermostat settings for both will simply tell that specific unit whether to come on or not.
However, they both feed air into the exact same ducts. The bedroom a/c is not an a/c that cools only the bedroom. If it were not very hot, I suppose you could run zone 2 only, and cool the whole trailer. Zone 1 also cools whole trailer. That's how I understand mine works.
And it's possible trailers are all different in that regard. And it's also possible I'm misunderstanding it.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 06-12-2016, 10:00 AM   #5
Danny & Esther
2016 F350 Dully
Does the fan come on?
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 06-12-2016, 11:39 AM   #6
chesbass
Zone 2 AC
Sounds to me like the zone 2 air conditioner compressor is coming on because the thermostat is calling for cool air yet the blower motor is not running it sounds like you could have a failed blower motor on that air conditioner therefore it shuts down because of no fan.
Danny & Esther
2016 F350 Dully
chesba88 is offline   Reply With Quote
Old 06-12-2016, 11:57 AM   #7
X2, to test the fan select zone 2 and press the fan for low or hi and see if it comes on..
2016 Siverback 33IK
Old 06-12-2016, 02:19 PM   #8
No. I do not hear fan come on
Old 06-12-2016, 02:20 PM   #9
I do not hear fan coming on.
Old 06-12-2016, 02:22 PM   #10
chesbass
No Fan
Like I mentioned earlier you probably have a bad fan motor.
