Old 07-30-2019, 04:31 PM   #1
Dometic A/C cycling
We have Dometic A/C unit that starts up immediately after shutting down. Cycling. If I remove our intake filter foam it seems to work fine. I have washed it out but still does same thing. Does anyone else have this problem and is there a less restrictive filter availible?
Doug Currie is offline   Reply With Quote
Old 07-31-2019, 11:58 AM   #2
Head Rambler
How old is the A/C?
Which thermostat do you have?
Could it be that it's switching fan speeds? On some units if the fan is in auto, it will stop for a few seconds when it's either nearing or drifting away from setpoint and switch speeds.
Also check the freeze coil and make sure it's against the evaporator fins.
When it shuts down pull the filter off quickly and see if there's frost on the evaporator.
Gotta go campin!
Old 07-31-2019, 12:02 PM   #3
Flybob's Avatar
If starting a ducted AC for the first time after arriving at the campground in a hot humid environment, it is best to open the dump valve to allow for maximum air flow to prevent freezing. Once the inside temp and humidity are decreased, you can close the dump valve and it will operate fine.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-31-2019, 12:06 PM   #4
It is on a 2015 33RL
Has Domectic small black square digital thermostat. See photo.Click image for larger version
Old 07-31-2019, 12:07 PM   #5
Does it with dump valve open as well
Old 07-31-2019, 12:47 PM   #6
Head Rambler
You can try initializing that thermostat and see if that helps. I doubt it will since you say that removing the filter stops it from happening.
Gotta go campin!
Old 09-02-2019, 12:59 PM   #7
I have the dual zone t-stat in our CC 34IK which was short cycling. Dometic said that's how they're supposed to work. After digging around on the Dometic site I found the installation manual for our 15k btu unit which along includes the user manual for the t-stats. After being told there was no offset adjustment I found, in the manual of all places, the instructions for adjusting the setback or dead band.
See if you can find your unit manual online and follow the instructions to set your offset to 2F instead of 1F and I bet it will quit cycling. Mine did.
TCrossan
2020 CC Hathaway 34IK, 2012 F350
tcrossan is offline   Reply With Quote
dometic
