07-30-2019, 05:25 PM
dometic ac
I was on the roof today, and looking at the ac's to see if they needed cleaning. I noticed that the rear one says on the label that its a 13500, I had assumed that I got the 15000, as to my future travel will be out west. The front states 13500, which I can live with. Where could I run the ser # to confirm its a 13500. Tried calling the dealer, but closed now. Thanks
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2, Hydra Star disc brakes,
400 watt Rich solar on top,200 watts of suitcase
07-30-2019, 05:48 PM
Coach
If you remove the cover you'll find somewhere in there the serial and model number. You can cross reference the model number in a google search. I'd be a little surprised if a CC had two 13,500s, but anything is possible.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
07-30-2019, 06:02 PM
remove the trim collar in side and there is a sticker with model number. My build sheet says my rear is 15 and the front is 13.5 but the part number for the front one is 15k. have not yet checked the rear. who knows maybe I lucked out and got two 15k.
07-30-2019, 06:12 PM
07-30-2019, 06:15 PM
The ser # is 53425824
07-30-2019, 06:29 PM
I took the cover off
07-30-2019, 07:29 PM
Originally Posted by wls
My roof near our rear A/C looks just like this. Planning on cleaning it up this weekend.
Wonder what causes it....
07-30-2019, 07:59 PM
I'd guess they didn't clean the drain pan before installing??
2011 Traverse LT, 3.6L, FWD
07-30-2019, 08:27 PM
its still blows cool, not sure if it is up to spec or not.
Wonder how you test it.
07-30-2019, 08:28 PM
I still think I should have a 15000 on it
08-26-2019, 07:29 PM
wonder where I could run my vin #, to see what it came with.
Talked to the dealer, he sort of stalling, waiting to hear back from the rep. A 42' coach, you would think a 15000 would be the very least they would put on.
08-26-2019, 08:23 PM
Have you thought about calling Cedar Creek and asking them nicely to check the build sheet for your VIN? Give them the serial number to make sure it matches what it was built with in case the dealer swapped it for somebody else.
Retired 2020.
46 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
08-27-2019, 12:57 PM
Ya I think I will call the dealer, then call cedar creek if I get the run around from the dealer. Thanks
08-27-2019, 05:32 PM
Ok but the dealer probably won't have the serial numbers off the units as they were installed. If they pulled one from yours you'll never know. Cedar Creek will know exactly what unit was put on your RV when it was built.
Retired 2020.
09-02-2019, 08:32 AM
I sent my vin #s to cedar creek, on the build it shows I ordered the 13500, in the bedroom. But the 15000 is standard with the Hathaway Edition. So I need to reach out to the dealer, and set up a date to have the correct one installed.
09-02-2019, 09:53 AM
Be sure the dealer knows that CC has authorized the replacement at NO cost to you.....since it would appear they made the mistake.
If the dealer doesn't have a 15K AC unit in stock, I would hold off taking your rig to them until they have one available...you could be without your trailer for some time otherwise.
Good Luck.
Mike K
2019 Cedar Creek 34RL2 w/disc brakes
2017 GMC 3500 D/A, DRW, 40Gal Aux Tank
USN 76-82
Retired Dept of Navy: Navy/USMC Flt Test Engineer
09-04-2019, 06:06 AM
I did have some email contact with a sales lady from the factory, they said to contact the customer service, so I sent the email chain to the web site, along with the 2016 CC brochure stating the Hathaway edition comes standard with the 15000 main AC. Hopefully they will tell me to go to the factory, or dealer to get the correct AC installed.
09-04-2019, 06:10 AM
Here's a pic
09-04-2019, 10:28 AM
there's black streaks coming out if it. It still blows cold air. Seems like I recall some other people having streak problems. Maybe tomo6 I will pull the cover off.[/ATTACH] Attachment 211183
I also have streaks on my unit like OP.
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
