Old 08-28-2013, 08:06 AM   #11
ret2006's Avatar
Originally Posted by BarryD0706 View Post
From reading the manual, you can change the differential for Furnace mode but not for Cooling.
Dometic sure doesn't make it easy, do they? Wish I could just go out and get a GOOD Honeywell thermostat that would work.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 10-27-2013, 10:51 PM   #12
Thought I would add this here. The AC return air vents are going to be a problem, once you remove the vents a few times to change the filters, the screw holes are going to strip out. I searched and found these on E -bay. They are only available from Canada. I received them and installed them in about 15 minutes. The filters from Canada are very expensive, so I found a place that makes custom filters for $2.69 each and am having them made. You just flip down the cover, insert the new filter and you are done. Makes the job much easier and should last a long time.
gatogonow is offline   Reply With Quote
Old 10-27-2013, 11:12 PM   #13
Former Full Timer
Duckogram's Avatar
Good info. Thanks
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 10-28-2013, 06:16 AM   #14
gatogonow
where can I find those air vents on ebay, I would like to order the filters too.
spock123 is offline   Reply With Quote
Old 10-28-2013, 07:12 AM   #15
Vent Guard Return Air Grille 14" x 6" 10030 Furnace Retrofit ABS Plastic Dust | eBay
Old 11-06-2013, 03:09 PM   #16
I had the same problem with my 32RL Wildcat, at first Tom Johnson said it was air blowing on the thermostat, that was not it. Then they told me that was the way it was suppoused to work, that was wrong, once the temp got above 80 the A/C did not ever turn off, just cycle up and down. After awhile Tom Johnson thought it something that I wanted to whine about. It was like that when I traded but I had a lemon and after awhile you become a whinner when you take a camper back a lot. On my Cedar Creek now I just set the heat and set the cool and forget it on the thermostat , I never mess with the program setting, Camping World said just stay away from that setting, I have no problem now
5th wheel, cedar creek, dometic, wheel
