Old 10-16-2017, 10:16 AM   #1
Jeffco, MO
tedstr's Avatar
Dometic programable thermostat quit.
Use the AC until a cold front came through and now I cannot get the furnace or AC to work. Only a blank screen. No temp or mode displayed and only can set the clock. Any suggestions before I take 33IK in for repair?
Mary & Ted
2016 Silverback 33IK
2015 GMC Sierra 2500HD CrewCab Diesel/Super Glide Hitch
Days camped 09 -53, 10 -56, 11 -57, 12 - 55, 13 - 46, 14 - 50, 15 - 60, 16 -32
7 FROG Rallies (Goshen(4), Charleston, Amana(2))
tedstr is offline   Reply With Quote
Old 10-16-2017, 10:29 AM   #2
herbike's Avatar
Location: Garfield County, WA. Least populated county in WA!
Is it battery operated? The ones found in your house are most often. Maybe the battery died.
Days camped in 2015--180 days--2016--95 days
2017--107 days & counting
2016 t28FQDX Shockwave, New GY Endurance tires 7/17,TV-2015 Duramax with over 120,000 miles, with delete done, 2014 Polaris RZR 800 EPS/ 5000 miles
herbike is offline   Reply With Quote
Old 10-16-2017, 10:32 AM   #3
My thermostat had a similar problem and I turned off the breaker and it reset. You may try that. I completely disconnected the trailer first and that didn't work so I then hooked back up then turned off the breaker to just the ac and it started working. Hopefully you will have the same results.
whitewinghunter is online now   Reply With Quote
Old 10-16-2017, 12:20 PM   #4
Head Rambler
Which thermostat do you have?
Is it single zone or multi-zone?
Most of them are powered by 12 volts. So in order to remove power to it, you'll have to unplug from shore power AND disconnect the battery (turn off the disconnect switch).
Gotta go campin!
Old 10-16-2017, 02:06 PM   #5
curteric's Avatar
My Dometic thermostat is attached to a base plate on the camper wall. the wiring is attached to the base plate. Just snap the stat off the base, wait a moment, reattach. It's a whole lot faster and easier that dealing with the battery disconnect and unplugging.
2013 GMC 3500HD Duramax
2016 Cedar Creek Silverback 29IK
curteric is offline   Reply With Quote
Old 10-17-2017, 12:31 AM   #6
Jeffco, MO
tedstr's Avatar
Thanks for all the suggestions. Understand to try the Master Reset technique for electronic devices. Will try tomorrow. Yes it is battery operated but RV battery is good. It is a two zone thermostat, one for living room and one for the bedroom. I do have two ACs.
Master Reset technique is to remove all power for at least 10 seconds. Works on PCs and the Dish Receivers.
Mary & Ted
Old 10-17-2017, 01:41 PM   #7
Jeffco, MO
tedstr's Avatar
Thanks for the Info
Tried the Master Reset (Turned of AC and DC) and now my programmable thermostat works as it should. Thank you to all of your suggestions.
Mary & Ted
Old 10-17-2017, 02:17 PM   #8
Head Rambler
Thanks for coming back and letting us know that you got it fixed.
Glad it was as simple as a power cycle.
Gotta go campin!
Old 10-17-2017, 09:52 PM   #9
Bluepill's Avatar
We are indeed living in the era of schizophrenic microprocessors.
2008 Itasca Meridian 37H
Bluepill is online now   Reply With Quote
Old 10-21-2017, 09:09 AM   #10
edt
Very interesting reading in Manuel hit any button then power button every thing comes back
North Ga
2015 40' cls
Never to be moved
edt is offline   Reply With Quote
dometic, thermostat
