Originally Posted by Fifth Wheelers
Has anyone had issues with the front door sticking on the 38EL? If so, what did you have done to correct it? Each time we have gone camping the door sticks more both at the top and bottom.
Does the door stick when NOT on stabilizers? What kind of levelers/stabilizers are on your unit?
If it sticks ONLY after you have leveled it, then it sounds like the frame is twisting to the point that the door is now cattywompus in the opening. If it sticks all the time, it sounds like the door or opening were not cut properly.
The only time I had a door sticking problem was on my TT with manually operated stabilizer jacks. If I put too much lifting pressure on one of the corners, the door would stick.
2014 Prime Time Sanibel 3250
