Old 09-24-2015, 01:24 PM   #11
Global Nomad
Scheinin's Avatar
I just ordered a Cedar Creek with 4 six volt in series and parallel.
Scheinin is offline   Reply With Quote
Old 09-24-2015, 01:26 PM   #12
TURBS's Avatar
Huh?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
Old 09-24-2015, 01:33 PM   #13
TURBS's Avatar
You mean this right?
TURBS
2011 32bhok Sabre
Old 09-24-2015, 01:40 PM   #14
Originally Posted by TURBS View Post
Huh?
TURBS
2011 32bhok Sabre
When you run four 6v battery's, you need to run two groups of 6v battery's in parallel, and then hook up the two groups in series. If you hook all 4 together in series you end up with 24v. If you hook them in parallel you end up with 6v. I hope that helps.
Ditchdigger is offline   Reply With Quote
Old 09-24-2015, 01:42 PM   #15
DaveSchwartz's Avatar
Maybe the dealer's doing it that way for him at special request. The 'second battery' option on my TT was a dealer-installed thing and both batteries were the same so I think the dealer supplied them both. The only thing the factory did was have two battery trays.
And hasn't it been mentioned here that the provision of batteries is a dealer thing anyway? Especially with stock units, the factory has no idea how long they'll sit on the lot - why would they ship batteries that could die before the unit is sold?
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 09-24-2015, 01:52 PM   #16
SlowrideHD's Avatar
My 5er came with a 12v that wasn't all that large and would run down in a week just because of all the tiny drains from electronics, etc. I bought the largest deep cycle marine battery at Wally world and added it (in parallel, of course). Have never had a problem with the mix and it has been that way over a year and a half.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 09-24-2015, 01:55 PM   #17
Herk7769's Avatar
Attachment 89744
TURBS
2011 32bhok Sabre
This is exactly right.
HAM CALLSIGN - KC3FFW
Old 09-24-2015, 04:01 PM   #18
Global Nomad
Scheinin's Avatar
Attachment 89744
TURBS
2011 32bhok Sabre
That is correct, 2 6 volts in series to make 12 volts, then each set in parallel gives me 440 amps.
Old 09-24-2015, 04:09 PM   #19
Herk7769's Avatar
That is correct, 2 6 volts in series to make 12 volts, then each set in parallel.
It is important to note that the wires must be connected exactly like in Turbs drawing to allow each battery to be properly charged and discharged.
If both load wires are connected to the same 6 volt "pair" the second 6 volt "pair" will loaf and the lead set will have their life permanently shortened.
See attached PDF
Old 09-24-2015, 04:53 PM   #20
Batteries store power, We are running 2 thinking of added 3. We charge them either by converter or 2 180 watt solar panels, depending if we are RV park or dry camping. Generator for back up power and to run AC if needed, we also have an Inverter.
Pursell is offline   Reply With Quote
battery
