Drain issue on 2016 CC Silverback 37BH
Diesel guy, thanks for the reply! Had done some checking and found out the info on the hepo valve. Went under and disconnected the valve. Pushed the valve back into its right position and re-installed. No leaks. Appears when the level came up from full gray tank, it caused the valve to flip in the wrong direction causing the tub not to drain properly. Dumped 5 gallon bucket down the drain with no issues. Thanks again!
