Old 10-06-2019, 03:38 PM   #1
Drawer Removal
Hey, we have a problem with our waste can drawer. Basically they put a dinky screw in the slide and it came out.
But I canít figure out the trick to remove it from the slide mechanism so I can fix it. I didnít want to get carried away and break it.
Any of you had this problem. Iíll ha e Orvan show me in a couple of weeks if you folks donít know.
MikeRP is offline   Reply With Quote
Old 10-06-2019, 04:27 PM   #2
If the slides are like the ones in my Sunseeker, look for two small plastic "fork" like things on the slides and press them together while you pull out on the drawer. Sometimes you have to - press down on one side and up on the other.
Hope that helps!
Phil
PhilG is offline   Reply With Quote
Old 10-06-2019, 04:31 PM   #3
rracer5's Avatar
Hope that helps!
Phil
X2. Also, pull drawer slide all the way out to expose the release lever. Then, push slides back in about a half inch, press & hold the release levers while pulling out the track.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
