Old 04-12-2014, 07:28 AM   #1
BoatDude's Avatar
Early Bird camping
We are wanting to go open up our 2013 36ckts camper this weekend. It going to get down to 29 degree in a couple days. If we de-winterize it ( water pressure) today 75 degrees is a couple nights of cold temp putting us at risk of freeze damage? We can't leave the furnace on until next weekend...it's a a seasonal site about an hour away.
Sent from my SPH-L900 using Forest River Forums mobile app
2013 36 CKTS
2014 Ford F350 CC/DRW/PSD/Lariat/
Factory Installed Reese Custom 25K/
ReTrax Pro Cover
BoatDude is offline   Reply With Quote
Old 04-12-2014, 07:56 AM   #2
Kaadk's Avatar
I can't guarantee it won't freeze, but if you unhook the hose and open all your taps ( to release pressure) if it does freeze it'll have room to expand and will reduce the risk to a burst pipe.
Though if you can leave your furnace on next weekend, why not just wait until then?
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 04-12-2014, 08:03 AM   #3
mark0224's Avatar
You could play it safe after you use it you could just use a compressor to blow the lines out, at least make sure you dump water out of water heater and open low drain and all taps as previously mentioned. Blowing the lines out with the compressor only takes a few minutes and you should be very safe then.
mark0224 is offline   Reply With Quote
Old 04-12-2014, 08:06 AM   #4
Dovetail's Avatar
If you have electric available, u could hook up one of those little ceramic heaters
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
Dovetail is offline   Reply With Quote
Old 04-12-2014, 02:59 PM   #5
We're full-timers and we've experienced quite a bit of sub-freezing weather. Usually temps in the upper 20s for just a few hours will partially freeze exterior water lines but nothing in the RV. Temps in the low 20s or teens or a freeze of 12 hours or more is another story!
I know you won't be plugged in at all, but just saying -- slightly sub-freezing temps for a short duration is nothing to worry about. Release water pressure and I think things will be fine.
F-350 Dually
Cedar Creek Silverback
Mazda Miata TOAD for sex appeal
danno2u is offline   Reply With Quote
camping
