Old 10-14-2014, 11:33 AM   #1
mycedarcreek's Avatar
Electric rear stabilizer jacks
Cedar Creek 36ckts rear stabilizer jacks just quit working wasn't able to detect y any help.
mycedarcreek is offline   Reply With Quote
Old 10-14-2014, 10:30 PM   #2
jkaspar20's Avatar
A wire that may have pulled out from connector.
had issue on mine .. wire pulled out from connector
or Look for a in line fuse near motor.
jkaspar20 is offline   Reply With Quote
Old 10-26-2014, 08:10 PM   #3
Can't find a in line fuse so far can't find any loose wires. This doesn't make any sense
Old 10-26-2014, 10:50 PM   #4
jkaspar20's Avatar
Sound like time to get the volt/ohm meter out and start checking for the voltage.
I would start at the switch. If you get no voltage, I would use a wire toner and trace the wires in fuse box. I read somewhere in the Forums where there was an issue where a screw went thru the wire and opened the circuit up.
My Fantastic roof vent. Sometimes it would work and sometimes not ,I just found where a spade lug disconnected from circuit board.
electric, jacks
