Old 12-26-2018, 01:56 PM   #11
bob213's Avatar
Overhead lights and heater are 12v so you are either running off your battery or your converter is working. Microwave is 110v so you are getting ac power. Have you found your circuit breakers yet? Have you looked for a GFI plug that may have tripped? If the microwave is lit up why can't you use it? Converters are mounted everywhere and I don't know your trailer. Look under the oven or refrigerator. Under the bed, behind a panel in the bathroom or bedroom. I don't think it's your converter but you do need to find your circuit breakers and check them. Good luck. Let us know your progress. No one can help if we don't know what you have checked and found.
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ayn Rand
bob213 is online now   Reply With Quote
Old 12-26-2018, 02:08 PM   #12
If the light is on at your Microwave we've established that you do have power coming in to the unit.
Look at all of your wall outlets for one that has two square pushbuttons in the center of them. One will be a "test" button and the other the "Reset". If one (the reset) is sticking out a little more than the other firmly push it in until you feel it "click". You may have to use something like a pencil (eraser end) gripped in your hand to push if you're fingers aren't strong enough.
Ground Fault Interrupters are usually near a sink in the bathroom and then feed other outlets in the living areas. They are prone to tripping for a myriad of reasons like plugging in a heater, etc.
As for finding the converter/power panel, keep looking for a panel that you can open by either pushing or turning a lock knob. Should stand out clearly once you are looking in the right place
I have it on my dog's authority that an afternoon nap is acceptable.
Politically Incorrect since 1943
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 12-26-2018, 02:13 PM   #13
CincyGus's Avatar
Good post above.
If your overhead lights quit in a day or so, you have been running on the battery and it has died. If not, your converter is working and keeping the battery charged which will allow your 12v items (Lights, radio) to keep working. Microwave is definitely 110v as is your Air conditioner. Since the micro is getting power, the pedestal appears to be working and giving power to the RV.
RV's are different model to model where they mount the converter. Some have inverter/converters combined. Look for a panel that has circuit breakers and fuses. Generally it's brown and about 12"x10" and located places there is space that would otherwise be wasted. Often below the fridge, the bottom half of a cabinet, under the bed on one of the three walls of the bed support, sometimes under the sink in the kitchen or bathroom.
It will look something like this:
https://www.rv.net/forum/index.cfm/f...print/true.cfm
Let us know your progress and we can try to help.
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
Old 12-26-2018, 02:22 PM   #14
I just looked at a "Virtual Tour" of a Cedar Creek Cottage. Not sure if it's the same floor plan but If there is a "pantry" or "wardrobe/closet" just inside door with a Thermostat mounted on the wall of the hallway, look inside the pantry/wardrobe. Would most likely be mounted down low.
2004 Nissan Titan
Old 12-26-2018, 03:39 PM   #15
jd50i's Avatar
Cedar Creek 38 FB2 Converter Location?
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
jd50i is offline   Reply With Quote
Old 12-27-2018, 09:40 PM   #16
emergency help answer
Today I finally found the converter in an obscure place. The new converter has been ordered now and will arrive the day before my RV tech gets here. I am so relieved and thanks to all who tried to help. I got a better converter than the one that came with the trailer so hoping it will last lots longer.
Judy Wms. is offline   Reply With Quote
Old 12-28-2018, 06:42 AM   #17
jd50i's Avatar
any chance of posting the location for others who might need the information?
2014 Grey Wolf 21RR
Old 12-28-2018, 07:25 AM   #18
D W
D W's Avatar
Been following this thread. Confused to say the least. Light on in the microwave, but can't use it? Ordered new converter?
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline   Reply With Quote
Old 12-28-2018, 07:27 AM   #19
cavie's Avatar
If you have light at the microwave you have power. You say all electric is out. The converter has nothing to do with 120 volts. It provides 12 volts. Why would you buy a new converter you don't know what the problem is? if the micro has light why can't you use it. If you have overhead lights then the converter is working!!!!
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 12-28-2018, 09:42 AM   #20
dcheatwood's Avatar
I'm guessing she may have meant that the light in the hood, under the microwave, was working. Sounded desperate for help but maybe not knowledgeable enough about systems to understand all the good advice offered here. Hoping she'll report back with outcome.
2018 Forester 3011 DS
