Old 11-19-2014, 10:05 PM   #11
Confused?! I have 2015 33rl. As you step inside the door, within ez touch on the sink wall should be a panel with switches. One operates the fan and light in the main living area. Turn on the light portion by pulling the attached chain and shut off by using the wall switch. When entering from outside, hit the switch. BAM! Should have light.
I also keep a small flashlight on the counter to see inside that wall cabinet. I will eventually install a light that comes on when you open that panel door.
Bear in mind, my 2015 was a first production series. I did the factory tour at the Rally in Goshen but cannot recall subtle differences.
By the way, my wall switch was not wired correctly at the factory and did not work for 3 months until we attended the Rally and had it repaired in 3 minutes! Just say'n!! 😁
SilverbackMel is offline   Reply With Quote
light
