Old 12-25-2013, 04:54 PM   #1
Exhaust brake
I would like to know if anybody with 2002 F350 what kind of Exhaust brake you have on your truck and how it works !
Cowboy52 is offline   Reply With Quote
Old 01-10-2014, 08:08 AM   #2
Fulltime family RVer
Unfortunately I have a newer Dodge that has one. Hopefully someone comes along with info about the 2002 Fords to help you out.
Old 01-10-2014, 08:41 AM   #3
OL Creeker's Avatar
Your Ford
Nah, I drive a GMC. I just wanted to have a little fun.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 01-10-2014, 09:56 AM   #4
There are several aftermarket exhaust brake options for your (I am assuming) older 7.3l diesel such as Banks, BD, Pacbrake, and D-Celerator. I haven't ever heard anything bad about any of them but since they are all aftermarket you will have to learn the particulars about each of them as they all differ a little bit. Expect to pay around $1500+ for everything before install with Banks being likely the most expensive (of course). Some people even electronically control the heat riser valve and transmission torque converter and use that as a less expensive "sort of" exhaust brake. I think BD calls it a BrakeLoc. Expect to pay $400-500 before install. I would suggest going to a good Superduty truck website forums like ford-trucks.com or powerstroke.org in order to get more info.
A lot of the 7.3l owners will upgrade their brakes and find that a exhaust brake is less necessary unless you are pulling more than the truck is rated for. Unfortunately with your 7.3l F350 you will find you will run out of payload long before you get to the GCVWR of the truck. Slotted cryo'd rotors and high performance pads help quite a bit and are cheaper tun a exhaust brake if you stay within your ratings.
Mtelkman is offline   Reply With Quote
Old 01-10-2014, 10:11 AM   #5
Ford Idaho's Avatar
One guy at my work installed this on his 03' 350 4X4, say's it is worth the money and does not take long to change out.
He pulls a 30 foot enclosed trailer with four snow machines and gear/gas...
Forgot link.
http://ssbrakes.com/i-10093222-calip...grade-kit.html
I would rather mod the brakes than add on to the engine something it was not built for.
Old 01-10-2014, 10:12 AM   #6
Thanks for your reply were going to travel and some of the mountains I really don't want go down without a exhaust brake !
Old 01-10-2014, 10:29 AM   #7
Denver, CO
garbonz's Avatar
Banks makes an all electronic brake for the Duramax that is FABULOUS, but I don't think it works for the Ford's...
2017 Fuse 23T
brakes
