10-09-2019, 11:47 PM
#41
Noob
Maybe if you cool bland foods like mashed potatoes, patched eggs, and steamed broccoli. [emoji1785]
Originally Posted by TheWolfPaq82
Don't burn your food. No smoke.
10-10-2019, 05:28 AM
#42
My wife could burn water.
When she cooks, sometimes there's so much smoke, the neighbors smoke alarm goes off.
10-10-2019, 06:11 AM
#43
My 5er doesn't have a fan vented to the outside either but I do have a powered ceiling vent in the ceiling above the stove. It runs on a thermostat. I use it in conjunction with the stove vent. We still have the food smells in the trailer afterwards tho".
10-10-2019, 07:08 AM
#44
[emoji23]🤣[emoji481]
10-10-2019, 07:29 AM
#45
This thread and comments reminded me of a situation that happened to us a few years back.
We were camping at Fort Wilderness over Father's Day week and on Father's Day, my darling bride wanted to make me breakfast. So she got up early and started cooking. Well....smoke detector (which was right at the door) went off. The neighbor next door was a firefighter, heard the smoke alarm and did what firefighters do.....jumped out of bed in his jammies and ran over to our camper. Embarrassing for the Mrs who was trying to do good.
Needless to say, I don't think she has made breakfast in the camper since.
2019 Cedar Creek Silverback 37MBH
TV: 2017 Ford F350 CC DRW King Ranch
10-14-2019, 06:44 PM
#46
I have installed a hundred or so microwaves and I've never seen one that doesn't have the option to vent up or out the back. You just need to find an rv vent kit and install a wall vent. You will obviously have to take down your microwave to spin the motor to vent out the back. Hopefully you have the template with the owner's manual. It's a fairly easy job.
10-14-2019, 06:54 PM
#47
A Cedar Creek with a built in microwave vents to the outside of the directly behind the microwave. Probably not hooked up correctly.
10-14-2019, 07:14 PM
#48
I lost a cover because I didn’t fasten it and went down the road.
10-14-2019, 08:41 PM
#49
When we purchased our Cedar Creek, it didn't have a vent going to the outside for the Microwave/convection oven. I called the factory and they sent the parts to our dealer and he put it in for us, no charge.
10-14-2019, 08:43 PM
#50
Check out the OP’s pic in his signature. His RV does not have an exhaust vent.
10-14-2019, 10:16 PM
#51
Just throw a binford 2500 in it
10-15-2019, 09:10 AM
#52
Vente veritas
I have a vent. Open for camping closed to keep critters and rain out when traveling or stored. With some cooking I open a window and turn on the bath vent. It pulls a lot of air.
10-15-2019, 09:43 AM
#53
Global Nomad
Because my cover is SO HARD to latch & unlatch, when I un latched it 4 years ago, I left it that way. No problems, no rodents or bugs come in. If it is a real bad storm, sometimes I can feel a breeze come in. I don't feel any cold air coming in during the winter. ( I have wintered to 7 degrees above 0.)
Steven J. Scheinin
2015 RAM 3500 4X4 6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
10-15-2019, 10:18 AM
#54
Thanks dalford! Just in case, here is a Pic.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
10-15-2019, 04:31 PM
#55
The tabs on the outside are very ,very difficult to open the flap!!!! When we pack up I jam a sponge up inside the vent cover to keep the flap closed....WORKS!!!!!!!!!!
10-15-2019, 07:41 PM
#56
On our Flagstaff micro lite 21DS the fan is controlled with a toggle switch to a 12VDC 3.0amp can motor. I'm wondering if it might be possible to replace the switch with something that I could control the speed, right now it's off or full, very loud.
Reading this thread gave me the idea so I have not done any home work, but thought someone might have blazed this trail before me.
John & Donna: Retired
Trudi: My Partner in Crime. R.I.P. 6/19
2018 Silverado Double Cab Z71
2018 FR Flagstaff Micro Lite 21DS
10-15-2019, 08:02 PM
#57
https://www.walmart.com/ip/12-Volt-D...10090302008005
This one is rated for 4.2 amp but you can probably find any number of dimmer switches at any auto parts store.
10-15-2019, 10:55 PM
#58
My Cedar Creek had a microwave blower that blew into the camper. I got the vent kit and cut through my camper and changed blower direction on the microwave. Don't cut deep. I found a 120 VAC wire running smack through the middle of the hole! Fortunately, there was enough slack in the wire to push it to one side. Then, we quit full timing and bought a house. Yup, you guessed it. Another stinkin' microwave that blew cooking smoke at the ceiling. I had to run duct up and about 6 feet to the side to get outside.
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
10-15-2019, 11:15 PM
#59
Originally Posted by SlowrideHD
This is a PWM dimmer which is what you want. Many people put in smaller PWM controls and small knobs. You can pick them up on eBay.
10-16-2019, 07:14 AM
#60
Ours did the same. Removed the unit from the wall and flipped the plate on the back so it vent out the rear to the outside. Two screws on the top and it lifts off the wall. There are instructions for changing the venting it your owners book
