Old 09-24-2018, 10:27 PM   #1
Extra Breakers for Washer/Dryer & inverter I don't Have
I have a 2018 CC 38EL. Looking at my breaker panel I have two breakers for Washer/Dryer and I only have one combo unit that uses one plug. I also have a breaker for "Inverter Refer". Does this mean my rig is wired for the stackable washer/dryer and for a residential fridge? I have the RV gas/electric fridge that does not use a converter - in fact I don't even have a converter. I also have a 12 volt fuse labeled "15 amp scare lights". I don't think I have one of those either.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 09-24-2018, 10:31 PM   #2
BandJCarm's Avatar
Your rig is wired for a washer, and a dryer, and a residential refrigerator. The inverter would operate only the res. refrigerator when on battery power only. You do have a converter, it charges the batteries when you are connected to shore power or to the truck.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 09-24-2018, 11:37 PM   #3
cavie's Avatar
A converter changes 120 volts AC to 12 volts DC. you do have one.
An Inverter changes 12 DC to 120 volts AC. You would have on If you had a residential fridge. You may be pre-wired for Washer/dryer combo. and Resi fridge.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 09-25-2018, 08:21 AM   #4
sh1pper's Avatar
I am surprised that you have an inverter because it is only used for a residential refrigerator. Even if you have a breaker, it might be empty. Easy to check.
Hugh and Fran
"Riley" the dog
2018 Cedar Creek 38EL Champagne
2017 Ford F350 SRW CC SWB 4x2
Demco Hijacker Autoslide 18k Hitch
sh1pper is offline   Reply With Quote
Old 09-25-2018, 08:41 AM   #5
I mis-spoke on the converter. I know about inverters vs converters. I do not have an inverter unless it is hidden real well. I guess I will have to look into the inverter breaker and see where it goes. My guess is that it may power the fridge for the 120 volt since it is a gas/electric.
Old 09-25-2018, 10:31 AM   #6
Indymule's Avatar
The wiring for the residential refrigerator is probably there. The inverter in located in the front storage compartment on the right side. There is a black curved plastic cover (backs up to battery compartment). Do you have 1 or 2 batteries? If they installed the inverter, it should have at least 2 batteries but I doubt it is there. There are individual circuits for the washer and the dryer both 110v located in the closet. We do not have the washer and dryer but I use those plugs to power some computer equipment that I located in the closet.
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
Fulltimers since May 2018!
2017 Ford F350 Crewcab Dually Diesel
Officially homeless and loving it.
Ham Callsign K9NDY
Indymule is offline   Reply With Quote
breaker, inverter
