Originally Posted by Skyliner
There have been quite a few reports of water in fuel causing expensive damage to high pressure fuel pumps/injectors with aux fuel tanks.
If you have to get one, please spend the 700-$800 for an aftermarket fuel filter system that does a better job filtering and separating water, ESPECIALLY if you own a Ford 6.7L.
Side note even more important to Ford owners in general, ALWAYS use Motorcraft filters. The fuel filters have a water blocker barrier to help avoid the costly repairs. Most aftermarket cheap filters don't. Don't be cheap, be sure to change them before there's a problem, not when it's too late.
This has been a Ford public service announcement. [emoji1]
