Old 03-29-2017, 05:53 PM   #1
extra fuel tanks
Whats the best system and simplest really for an extra fuel tank in truck
wingnut1955 is offline   Reply With Quote
Old 03-29-2017, 07:05 PM   #2
You didn't mention what truck you have or what size tank. My f150 had the little 23 gallon tank. I upgraded to to the oem 36 gallon and it is so much better.
2016 Coachmen Apex 288BHS
2015 F150 Sport 4x4 3.5 Eco Boost
4B11T is offline   Reply With Quote
Old 03-30-2017, 12:11 AM   #3
Depends on the truck. Diesel, the simple way is to add an in bed tank with a gravity feed kit. Legal in U.S. but not in Canada. Gas truck..change the original fuel tank for a larger one if you can..not any other options for gas.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 03-30-2017, 05:57 AM   #4
Campingnut's Avatar
I have always used a Titan tank.
Tim and Bev
2013 Cedar Creek 34RLSA gone trying to find my way back, Magnum 2800w inverter, 560w of solar.
2020 F-350
Campingnut is offline   Reply With Quote
Old 03-30-2017, 06:17 AM   #5
I had a welding shop build me one, I installed a 8 gpm 12 volt pump. It's 100gal tank, I have had it for 9 years. My Silverado holds 36gal. It's diesel
spock123 is offline   Reply With Quote
Old 03-30-2017, 06:44 AM   #6
Oh I forgot to add my complete tank sits below the top of the bed. You can find them at Tractor Supply and Titan makes them. I think I paid like 800 bucks for my system. I had a cover on my bed at one time and I had the tank in a short bed truck and I had the corners cut out so the tank would sit flat. My truck and camper hooked up has never been in a gas station. When DW and I stop at a rest area, we can use the bathroom in the camper, get something to eat and fill up the truck in about 15 minutes and be back on the road. When we stop for the night I take the truck and find the cheapest diesel and fill up then. Sometimes we stay hooked up but we can drive for two days without fueling up. At home the tank is easy to take out and hitch too so I can have a clean bed. I have a long bed truck now
Old 03-30-2017, 06:53 AM   #7
I have a Transfer Flow 50 gallon in the bed of the truck. I have an eight ft box. It fits under the tonneau cover. In-Bed Fuel Tanks - Transfer Flow, Inc. - Aftermarket Fuel Tank Systems. It has the computer but an older model than the one shown on the url. I had it installed so it wasn't exactly cheap but I can go a long way pulling a 35 ft 5er.
Pipeman is offline   Reply With Quote
Old 03-30-2017, 07:13 AM   #8
Insert witty title here
Way back in the day, my father had a 50 gallon aluminum tank with a 12V electric pump built that could fit between the seats on his little 12' skiff that he would use to bring gas out to his larger boat on the mooring. He no longer does this but still has the tank. He lets me use it whenever I want.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 03-30-2017, 07:19 AM   #9
Where did you get the tank and how much was it? Was it a DIY project? I'm in the same boat and while I'll likely never travel more that 180 or so miles between stops, it would be nice to have the breathing room.
JeffandLori is offline   Reply With Quote
Old 03-30-2017, 07:20 AM   #10
BandJCarm's Avatar
Transfer Flow with Trax3 system...................solves it all.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 03-30-2017, 08:41 AM   #11
Jim34RL's Avatar
There is also a diesel auxiliary tank that takes the place of the spare tire which will hold 30 gallons. This also does not take up any bed space in your truck. Here is a link to the tank: https://titanfueltanks.com/product-category/stafs/
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Old 03-30-2017, 10:31 AM   #12
I looked at the website, that's a lot more than I paid. The fuel meter looked nice
Old 03-30-2017, 10:56 AM   #13
BooBoo23's Avatar
You have to be careful about the use of auxiliary fuel tanks from a liability issue. If you are in an accident, and they do happen, and the fuel tank ruptures who gets the blame? Who pays for hazmat cleanup? When I worked for a truck equipment dealer we sold several types of aux tanks. They were all DOT approved and type tested. Although Transfer Flow is not cheap they are by far the best on the market.
Check this information out. https://www.transferflow.com/regulations
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 03-30-2017, 01:41 PM   #14
They can all get punctured , what's your point buy the most expensive. I would think my insurance would pay for the clean up, suppose there was no fuel in the tank. I have been using my for nine years and no problems. Well I did have a leak last year but I got that fixed
Old 03-30-2017, 06:46 PM   #15
I got the tank pump and heat shield from a local dealer. They matched the best price I could find online minus the shipping. I did the install myself.
Old 03-30-2017, 07:51 PM   #16
2007 WildCat 32QBBS
18CrewDually's Avatar
RDS fuel & tool box combo. All aluminum construction. Below the rail and can be simple gravity feed or electric pump. Advertised as a 91 gal but 88 is all I see out of it. Wouldn't tow without it.
http://www.rdsaluminum.com/
18CrewDually is offline   Reply With Quote
Old 03-31-2017, 05:09 PM   #17
talldiver's Avatar
Just installed a 50 gal Titan tank on my F350 replacing the 26 gallon that came with the truck.....LOVE IT!! We are finishing up our month long trip south and not once did I have to stop for fuel at a truck stop which we all know charge .20-.40 cent/gal over a station in town.
Why Ford would put a 26 gallon tank on any Super Duty is beyond imagination.
2015 F350 SRW 6.7 PSD
2016 38FB2 CC
Andersen Hitch
talldiver is offline   Reply With Quote
Old 03-31-2017, 05:28 PM   #18
Ford Idaho's Avatar
Mine has a 35 gallon tank per the manual, the Titan 50 gallon tank would be a bonus...
Old 03-31-2017, 07:37 PM   #19
There have been quite a few reports of water in fuel causing expensive damage to high pressure fuel pumps/injectors with aux fuel tanks.
If you have to get one, please spend the 700-$800 for an aftermarket fuel filter system that does a better job filtering and separating water, ESPECIALLY if you own a Ford 6.7L.
Skyliner is offline   Reply With Quote
Old 03-31-2017, 09:51 PM   #20
ba964's Avatar
Same as tail diver .Love it.
ba964 is offline   Reply With Quote
fuel, tank
