Old 12-21-2014, 03:42 PM   #11
Good luck
CCreek5th is offline   Reply With Quote
Old 12-21-2014, 06:07 PM   #12
I have a CC 38CK. The wiring is pre-installed to provide power only to the wireless receiver in the truck. My camera keeps loosing the signal, so i contacted the dealer that installed the camera. It was suggested to use the suction cup mount for the screen high up on the windshield, as the signal might be blocked by the height of the 5th wheel. I will try this in the spring, but I anticipate that I will need to change out the set-up.
CTGREG is offline   Reply With Quote
Old 12-22-2014, 09:51 AM   #13
Factory Rear View Camera
I have the Voyager WVOS511 wireless system. It worked fairly well on my 35' long Cardinal. It just got worse on my 36CKTS Cedar Creek. The screen would lock up or show no signal quite frequently. I called RV Cams and purchased a 35' extension cable which allowed me to mount the camera antenna on the top of the front cap. This totally solved my problem.
A friend of my totaled his 2014 36CKTS last October days after installing the same Voyager system. He took delivery of his 2015 36 CKTS last Friday with the factory installed rear view camera. When I asked how the camera system worked. His reply was not good. He will be installing his antenna extension cable on the new trailer.
C.B.
cbvp is offline   Reply With Quote
Old 12-22-2014, 10:56 AM   #14
DH installed the Voyager 713 on our 2014 36CKTS. It has a great picture and we have not ever lost signal. The only problem we had was FINDING the wires to install it, (they were hiding under all the insulation).
bkearney is offline   Reply With Quote
Old 12-23-2014, 02:50 PM   #15
Old Timer
Looks like FR just switched to Furrion from Voyager on the latest 2015's. I just bought a new Wildc at and it came with a Furrion installed. That's also what's showing in the latest version of the Wildcat brochure.
kentnjudy is offline   Reply With Quote
factory
