Old 07-07-2016, 02:40 PM   #11
Mark and Becky's Avatar
Hi Oakman (Bob):
Thought we had to have the Service Requests in by July 1st? Already turned mine in last month.
-Mark
Mark and Becky is offline   Reply With Quote
Old 07-07-2016, 02:47 PM   #12
Oakman's Avatar
When you go up to the service center they usually ask if you have any changes, I would at least mention it then. I consider this to be a safety item.
Last year I played the age card to get them to fix something extra on my rig.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 07-07-2016, 02:49 PM   #13
grumpy0374's Avatar
Originally Posted by OldCoot View Post
I replaced all the rivets with Gr 8 bolts and nyloc nuts. Stainless will not rust, but they are still soft.
X2. Depending on the grade of stainless steel used, they will be either too soft or too brittle. Not what you want to use for steps that will be constantly bearing weight.
Use either grade 5 (good) or grade 8 (best), and you'll never have another problem.
Grumpy
Steve & Cheryl + Charlie & Casey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
Camping trips this year so far...8
Days camping...75
grumpy0374 is offline   Reply With Quote
Old 07-14-2016, 06:44 PM   #14
Av8orLou's Avatar
Originally Posted by Mark and Becky View Post
Has anyone seen this rivet fail? Just got back from a trip in our 2013 34 RLSA, and found the rivet on the right side of the steps missing. Put a temporary fix on it, but it's not the correct one.
I have the same year and model Cedar Creek and had the same problem while it was under the original warranty. They repaired it it with grade 8 bolts but I believe they went to a 5/8 size bolt. I have since replaced the steps with a four step unit, much better built imo.
2015 GMC Denali HD Z71 4X4 - D/A
2004.5 Chevy D/A
2013 Cedar Creek 34rlsa
2003 Four Winns Funship 214 Deckboat - Hawaiian Breeze
Av8orLou is offline   Reply With Quote
Old 07-15-2016, 03:00 PM   #15
DKRITTER's Avatar
Not exactly sure which rivets your talking about? Are the 3 and 4 step units different?
If possible would someone post a picture.
2015 Ford F350 CC SRW LB 4X4
2016 Cedar Creek 36CKTS (My Last FR Product)
20,000 LB Reese GooseBox Hitch
DKRITTER is offline   Reply With Quote
Old 07-17-2016, 08:00 AM   #16
Av8orLou's Avatar
The four step is just easier to climb, don't have to take as big a step. I think the one I installed is just better made and rated for more weight.
2004.5 Chevy D/A
Old 09-06-2016, 07:39 PM   #17
PhoneDude 8289's Avatar
Replaced all the rivets on the steps with Gr 8 bolts washers and nyloc nuts as OC recommends, about a $3.00 investment in safety. Glad I did it when I did as two of the rivets were very loose. I used a cold chisel tool and hammer to knock the ends off and the rivets fell off. Check all the bolts and screws holding the steps to the trailer, several of mine were not tight at all.
Lifted 2014 8289WS Diamond pkg
2014 Ram 2500 4wd SB DC TCD
PhoneDude 8289 is offline   Reply With Quote
Old 09-27-2016, 09:37 PM   #18
CC replaced the steps as a Safety Item during the Goshen Rally.
