Old 07-06-2016, 08:16 PM   #1
Mark and Becky's Avatar
Fastening Hardware on the Steps
Has anyone seen this rivet fail? Just got back from a trip in our 2013 34 RLSA, and found the rivet on the right side of the steps missing. Put a temporary fix on it, but it's not the correct one.
Mark and Becky is offline   Reply With Quote
Old 07-06-2016, 08:24 PM   #2
Ford Idaho's Avatar
A bolt of the same size with two washers and a nylon nut should hold just as well.
Old 07-06-2016, 08:32 PM   #3
rattleNsmoke's Avatar
Lippert uses cheap-ass aluminum rivets that shear off at the scissor. I was carrying a case of wine up the steps and on the way back down empty handed the top step let go. I'm 6'4 and 260 lbs. If I was carrying that case and it broke I would have gotten perty banged up. I drilled out and replaced all the junk with Grade 8 bolts, washers and nylock nuts. No more issues.
rattleNsmoke is offline   Reply With Quote
Old 07-07-2016, 05:01 AM   #4
dwilhite's Avatar
You might check to see if there is a recall on them
God Bless,
David & Cathy
2015 Trilogy 38FL
2016 Silverado 3500HD DRW
Trailersaver TS-3 Hitch on B&W Platform
dwilhite is offline   Reply With Quote
Old 07-07-2016, 11:12 AM   #5
Replaced it with 1/4-20 stainless hardware with a self-locking nut. Seems to be doing the job! Thanks for the input.
-Mark Munger
Old 07-07-2016, 11:45 AM   #6
Mark,
If you haven't done so....replace them all. They will all shear off at some point.
Mike
Old 07-07-2016, 01:33 PM   #7
I agree with rattleNsmoke. I replaced all of mine with grade 8 bolts and nylon lock nuts.
Steve & Lee
Jacksonville, FL
2013 Cedar Creek 36 CKTS Touring Edition
2012 F350 King Ranch, Reese Elite 18 and Air Bags
Elkrun is offline   Reply With Quote
Old 07-07-2016, 01:36 PM   #8
Oakman's Avatar
Put it on your list of fixes for Goshen, perhaps you'll get a new set of steps.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 07-07-2016, 01:37 PM   #9
I noticed that the left side was also about to let go. They look like aluminum pop rivets. Not what I would use.....
-Mark
Old 07-07-2016, 01:40 PM   #10
I replaced all the rivets with Gr 8 bolts and nyloc nuts. Stainless will not rust, but they are still soft.
Old 07-07-2016, 01:40 PM   #11
Hi Oakman (Bob):
Thought we had to have the Service Requests in by July 1st? Already turned mine in last month.
-Mark
Old 07-07-2016, 01:47 PM   #12
Oakman's Avatar
When you go up to the service center they usually ask if you have any changes, I would at least mention it then. I consider this to be a safety item.
Last year I played the age card to get them to fix something extra on my rig.
Bob and Joyce
ATU Local 788
Old 07-07-2016, 01:49 PM   #13
grumpy0374's Avatar
X2. Depending on the grade of stainless steel used, they will be either too soft or too brittle. Not what you want to use for steps that will be constantly bearing weight.
Use either grade 5 (good) or grade 8 (best), and you'll never have another problem.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 07-14-2016, 05:44 PM   #14
Av8orLou's Avatar
I have the same year and model Cedar Creek and had the same problem while it was under the original warranty. They repaired it it with grade 8 bolts but I believe they went to a 5/8 size bolt. I have since replaced the steps with a four step unit, much better built imo.
2015 GMC Denali HD Z71 4X4 - D/A
2004.5 Chevy D/A
2013 Cedar Creek 34rlsa
2003 Four Winns Funship 214 Deckboat - Hawaiian Breeze
Av8orLou is offline   Reply With Quote
Old 07-15-2016, 02:00 PM   #15
DKRITTER's Avatar
Not exactly sure which rivets your talking about? Are the 3 and 4 step units different?
If possible would someone post a picture.
Former Owner of
2016 Cedar Creek 36 POS (My Last FR Product)
DKRITTER is offline   Reply With Quote
Old 07-17-2016, 07:00 AM   #16
Av8orLou's Avatar
The four step is just easier to climb, don't have to take as big a step. I think the one I installed is just better made and rated for more weight.
2004.5 Chevy D/A
Old 09-06-2016, 06:39 PM   #17
PhoneDude 8289's Avatar
Replaced all the rivets on the steps with Gr 8 bolts washers and nyloc nuts as OC recommends, about a $3.00 investment in safety. Glad I did it when I did as two of the rivets were very loose. I used a cold chisel tool and hammer to knock the ends off and the rivets fell off. Check all the bolts and screws holding the steps to the trailer, several of mine were not tight at all.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 09-27-2016, 08:37 PM   #18
CC replaced the steps as a Safety Item during the Goshen Rally.
