Old 07-06-2016, 08:16 PM   #1
Mark and Becky's Avatar
Fastening Hardware on the Steps
Has anyone seen this rivet fail? Just got back from a trip in our 2013 34 RLSA, and found the rivet on the right side of the steps missing. Put a temporary fix on it, but it's not the correct one.
Mark and Becky is offline   Reply With Quote
Old 07-06-2016, 08:24 PM   #2
Ford Idaho's Avatar
A bolt of the same size with two washers and a nylon nut should hold just as well.
Old 07-06-2016, 08:32 PM   #3
rattleNsmoke's Avatar
Lippert uses cheap-ass aluminum rivets that shear off at the scissor. I was carrying a case of wine up the steps and on the way back down empty handed the top step let go. I'm 6'4 and 260 lbs. If I was carrying that case and it broke I would have gotten perty banged up. I drilled out and replaced all the junk with Grade 8 bolts, washers and nylock nuts. No more issues.
1988 Harley Softail Custom "The Fireman"
rattleNsmoke is offline   Reply With Quote
Old 07-07-2016, 05:01 AM   #4
dwilhite's Avatar
You might check to see if there is a recall on them
God Bless,
David & Cathy
2015 Trilogy 38FL
2016 Silverado 3500HD DRW
Trailersaver TS-3 Hitch on B&W Platform
dwilhite is offline   Reply With Quote
Old 07-07-2016, 11:12 AM   #5
Replaced it with 1/4-20 stainless hardware with a self-locking nut. Seems to be doing the job! Thanks for the input.
-Mark Munger
Old 07-07-2016, 11:45 AM   #6
Mark,
If you haven't done so....replace them all. They will all shear off at some point.
Mike
Old 07-07-2016, 01:33 PM   #7
I agree with rattleNsmoke. I replaced all of mine with grade 8 bolts and nylon lock nuts.
Steve & Lee
Jacksonville, FL
2013 Cedar Creek 36 CKTS Touring Edition
2012 F350 King Ranch, Reese Elite 18 and Air Bags
Elkrun is offline   Reply With Quote
Old 07-07-2016, 01:36 PM   #8
Oakman's Avatar
Put it on your list of fixes for Goshen, perhaps you'll get a new set of steps.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 07-07-2016, 01:37 PM   #9
I noticed that the left side was also about to let go. They look like aluminum pop rivets. Not what I would use.....
-Mark
Old 07-07-2016, 01:40 PM   #10
I replaced all the rivets with Gr 8 bolts and nyloc nuts. Stainless will not rust, but they are still soft.
