Old 09-03-2013, 06:25 PM   #1
Grandmashome
Fifth Wheel Fiberglass Bulkhead
Must open up the fiberglass bulkhead on my 2001 Cedar creek - probably need to replace some wood in there. The front corner passenger side screw rail screws came loose as well as the passenger side corner excrusion screws when in an accident in March. Hadn't noticed it right away but water definitely went in. Correct me if I'm wrong: To open up the fiberglass bulkhead must remove the corner excrusions on each side, and loosen the lower part of the screw rails both sides of the hitch as well as remove the frame piece around the hitch. Then deal with wood. The front end cap will stay in place.
grandmashome is offline   Reply With Quote
Old 09-03-2013, 08:58 PM   #2
mike1poles's Avatar
You may get all kinds of answers and suggestions. I would say, call Mike at Cedar Creek, 260-593-2326. He will advised you exactly what needs to come off, and the easiest way to do it. Even with older units, they will help you with questions and advice.
Hope this helps and God bless,
Mike
Mike and Judy
Wherever we are parked is our home
2009 - 36RD5S
2007 - Dodge 3500 6.7 Cummins
May God bless
WA8MRU
mike1poles is offline   Reply With Quote
Old 09-12-2013, 06:34 AM   #3
Grandmashome
Thanks much. Every bit of information has been helping. Have to order more parts! Godspeed!
fiberglass bulkhead, fifth wheel
