Old 11-01-2013, 01:01 AM   #1
Filling Fresh Water Tank
I've got a Silverback 29RE. Does the fresh water tank have a vent to the outside? I was wondering if you have to open a valve somewhere to vent the tank when you are filling it with 66 gallons of water. The air has to go somewhere.
And how do you tell when it is full?
Pat & Karen
Seattle, WA
2012 CC Silverback 29RE
2013 Ford F250 Lariat, Crew Cab, Short Bed, Diesel, 4WD
Retired and trying to travel where it's warm.
pengle is offline   Reply With Quote
Old 11-01-2013, 01:24 AM   #2
Ford Idaho's Avatar
Mine has a over fill tube, water will spill out of it when it is full.
Old 11-01-2013, 01:52 AM   #3
sail2liv's Avatar
Get one of those filler attachments that has long tube and digital readout for amount of water going in.....there should be small vent next to the filling hole....good luck
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 11-01-2013, 07:03 AM   #4
gkeager's Avatar
Mine has an overflow. It's located behind the left rear tire. Hard to detect and sometimes makes a mess if you don't watch it closely. Love my trailer hope you enjoy yours!
Gerry & Kathy Eager
2013 Silverback 29RE
2005 Silverado 2500HD
w/Duramax & Allison Trans
gkeager is offline   Reply With Quote
Old 11-01-2013, 08:19 AM   #5
Former Full Timer
Duckogram's Avatar
Originally Posted by pengle View Post
I've got a Silverback 29RE. Does the fresh water tank have a vent to the outside? I was wondering if you have to open a valve somewhere to vent the tank when you are filling it with 66 gallons of water. The air has to go somewhere. And how do you tell when it is full? Thanks
Yes there is a vent. It's under the fresh water tank. Look for a blue tube with a cut
end hanging down somewhere near the rear axle on the ODS. Fill till water comes out, fill till your gauge reads full, or fill by time. 4 minutes will get you about 35 gals.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 11-03-2013, 05:23 PM   #6
Thanks Ducky, I found the blue tube hanging down near the rear axle on the driver's side.
Pat & Karen
Seattle, WA
fresh water, tank, water, water tank
