12-10-2017, 05:45 PM
Fire Place Access
We have a 2016 Silverback 33IK that I need to access behind the Fire Place glass to clean out some spider webs. I cannot see, or find, how to access the screws that hold the glass front in place. I am guessing that you need to remove the plastic brick surround first, but cannot figure out how that is accomplished. How is it held in place by ???
Anyone know how this is held in place. The instructions for the fire place show how to remove the glass for cleaning, so I'm good there.
Thanks!
12-10-2017, 08:44 PM
On our 2017 CC 34RL2, there is pin with a ring under the bottom center of the fire place. Pull the pin down and pull the the fire place out. Hope this helps.
12-11-2017, 08:43 AM
Ours has 4 Philips head screws, two on each side.
12-11-2017, 09:32 AM
Thanks!
I have a 2016, 34RL Cedar Creek. We had our trailer serviced by Cedar Creek at the F.R.O.G. rally a couple of years ago. The service technician had to pull the fireplace out to work on this and another issue. The technician removed the screws (black with Roberts/Phillips head) that hold the fireplace in the opening. He than had to slide the fireplace out of the opening. Once out you can access the glass by removing the bottom panel screws and the bottom panel. Be carful you do not damage the electrical wires and motor when you clean the glass.
Components are changed constantly and yours might be different than ours but this is how he was able to access this fireplace.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
12-11-2017, 12:39 PM
Thanks!
On my 2014 36ckts, the glass is not attached at all. Just lift up and out to remove.
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2019 F350 Platinum CC, PSD, 4X4, long box, SRW
Demco Glide Ride pin box
Demco Hijacker UMS 21K hitch
12-13-2017, 05:43 PM
I have the manual that explains how to access behind the glass, but nothing to show how to remove the fireplace so that the screws hold the face on can be removed. There are no screws or pins around the face of the fireplace. No access from the sides either. I guess we will live with the spider web for now. Thanks to all who answered.
12-13-2017, 05:53 PM
check if there is a trim piece on the fireplace that surrounds the edges. Mine you lift up on trim piece then you can access the screws that hold it in place.
Push up from bottom on the sides to lift trim.
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
12-13-2017, 10:28 PM
On mine there is a trim board above the fireplace, remove the 2 screws to remove it. Then there is U shaped metal trim around the top and sides that you slide up about a half inch and pull it off. Then you have access to the 4 screws securing the fireplace.
Almost not an SOB
Artic Fox 3018 5th Wheel - on order
Grand Design 2800BH TT 2021
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
