Old 08-31-2019, 10:23 PM   #1
Fireplace access 36CK2
How do I pull out my fireplace? A year ago when we bought this new 2018 the dealer showed us everything in 60 minutes, the fireplace access probably took 4 seconds of that 60 minutes. What do I pull/push/twist/turn/lift to pull out fireplace?
Where is the knob/lever located to pull/push/twist/turn/lift....top/bottom/center? A picture would be fantastic!
Thanks so much
2019 CC Hathaway 36CK2
2006 Ram 3500 Dual Wheel Cummins
Fleetwood PA
acvp1 is offline   Reply With Quote
Old 08-31-2019, 10:50 PM   #2
Thanks so much
On our 2018 36CK2 there is a latch at the bottom in the middle with a ring to pull straight down that allows the fireplace out. Look for the pull here label, it is below that. Pull straight down towards the floor not out towards you. Also be aware that the ring pulls apart quite easily as the original is real cheap. Nearly scrapped up my finger pretty bad when I I did it the first time. Replaced with a solid type key ring. Note have to make sure you don't pull down too far or the latch will slip out of the slot. Not hard to put back when you get on your stomach to see what needs to be done. You will need to make sure that the fireplace latch is actually latching or the fireplace will come out while traveling.
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2015 Chevy 2500HD Crew Cab 4X4 SRW Duramax
Demco AutoSlide 18k
GMRCK25D - Rear Axle Timbren SES Suspension Upgrade
LittleBill is offline   Reply With Quote
Old 08-31-2019, 10:53 PM   #3
Thanks a million !!!!!!!!!!!
Fleetwood PA
fireplace
