Old 02-07-2016, 09:32 PM   #11
Why use antifreeze when compressed air will do the job?
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
Sterlingsilver is offline   Reply With Quote
Old 02-07-2016, 09:56 PM   #12
Popcorn! Youroo!!
Old 02-24-2016, 08:31 AM   #13
DKRITTER's Avatar
Since we are in Texas we tend to use our trailer during the winter and not so much in the heat of the summer unless we head north for a few weeks.
I tend to sanitize once a year and that's late spring early summer. I also don't use antifreeze unless i feel we are going to get a very hard freeze, I do a good job of draining the trailer then blowing all the lines out. Now I do put some antifreeze in the bowl and traps.
Trailer lives on the side of my shop in the backyard so I get a beer or 3 and have at it.
2015 Ford F350 CC SRW LB 4X4
2016 Cedar Creek 36CKTS (My Last FR Product)
20,000 LB Reese GooseBox Hitch
DKRITTER is offline   Reply With Quote
Old 02-24-2016, 09:43 AM   #14
We tend to go somewhere every month and since we live in the southern part of NC, I normally just keep heat on camper but this year I did winterize the camper. This Sunday I plan to clean all the RV antifreeze out, we leave on a little 3 week trip next Tuesday. Now I get to camp a lot, the magic day in next Monday.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 02-24-2016, 01:35 PM   #15
Did both air, then anti freeze. Just came south for 5 weeks. Ran pressure water thru the system to clean it out. Cleaned water filter housing with bleach; shut off system from water first; then after NEW filter was installed re energized water system.
We used all water extensively today for 2 showers.
We use bottled water for a few days for drinking or coffee until systems pass a lot of water. Then all clear.
SilverbackMel is offline   Reply With Quote
Old 02-24-2016, 01:40 PM   #16
Herk7769's Avatar
Originally Posted by Scheinin View Post
Thank you for your responses. Eventually we plan to boondock, so I will sanitize as soon as I figure out how to by pass the water heater. The 2016 comes with the instant hot water, but I would think there would be antifreeze in there also, would that not be correct?
I don't have instant hot water, but I understand it is a flow through system (basically a pipe with a heating wire coil around it). Should not involve isolation during winterizing or de-winterizing.
If someone knows more about it please chime in ...
HAM CALLSIGN - KC3FFW
Old 02-24-2016, 02:06 PM   #17
SeaDog's Avatar
Having just found the condition the factory leaves things that you can't see debris and such I would not take the dealer's word it was OK to just flush, you have no idea of what might have been left in the tanks at the factory. Bleach is cheap a cup full or two overnight in the tanks will kill most anything then a good flush and you will be good to go, that is my plan for the end of March and my first real camping trip with the Flagstaff.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 02-26-2016, 12:34 AM   #18
JohnF's Avatar
[QUOTE=Flybob;1096642]X2 Sanitize it only takes a short time and is worth it. Make sure WH is bypassed when you sanitize.
Why bypass the hot water heater?
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
winter
